Old 07-29-2016, 12:04 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
Well from a PCV point of view you should be covered though I still would consider a catch can, especially if you will autocross or track the car in the future.
Regarding the steam vent line, yes connect it to that port on your radiator. 1/4" ID hose will fit the steam vent barb on the engine.
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 07-29-2016, 12:45 PM
CamaroBill's Avatar
CamaroBill CamaroBill is offline
Thank you, will do on both! By the way, love your car and great YouTube vids!
67 Convertible Camaro RS LS3, 6 speed
64 Malibu SS RamJet 350
64 Ford Falcon Sprint 342 SBF, 6 speed (sold)
68 Nova LS1, 6-speed (sold)
67 Camaro 421 SBC Procharger (traded on Lateral-G)
68 SS Camaro 350 (Sold on Lateral-G)
70 Nova LS1 (sold)
The beatings will continue until morale improves
Old 07-29-2016, 01:25 PM
dhutton dhutton is offline
What is connected to the orifice tube in the drivers side? LS3 crate engine instructions say to tee the two tubes together and take them to the intake before the MAF...
At least that is my recollection.
Old 07-29-2016, 06:48 PM
CamaroBill's Avatar
Don, are you referring to the one that's capped off above the steam vent in the picture? If so, that's not connected to anything.
70 Nova LS1 (sold)
Old 07-29-2016, 09:47 PM
randy randy is offline
Originally Posted by CamaroBill View Post
Dave, as I mentioned in my last post this car is new to me and I'm trying to "fix" any deficiencies that I come across. I really appreciate you spotting that and chiming in. Yes it is capped! There's a bung in the radiator near the cap, think that's a good spot to connect that to?
Take the cap off and run a line to your radiator. You need a steam vent
Old 07-29-2016, 09:49 PM
Chad, thank you so much for taking the time to explain that, and the link to the "CCV bible " , a ton of good info there. I just bought this car and I'm trying to make sure it's squared away before I really push it. I dug into a little more and discovered that the tube from the valley cover is looped to the vacuum port behind the throttle body. Here is a picture.
That is what i used to then run to my oil catch can. Here is my setup
Old 07-29-2016, 09:59 PM
CamaroBill's Avatar
Yes, I will do that, thank you.
70 Nova LS1 (sold)
Old 07-29-2016, 10:02 PM
CamaroBill's Avatar
Nice set up, added to my "to do" list.
70 Nova LS1 (sold)
