Old 09-03-2016, 05:48 AM
vstol vstol is offline
Default No fliud to the rear brakes
Just bled my Wilwood MC manual brake setup and went to bleed my rear brakes but no fluid. Could it be I have my brake actuator arm to tight and not coming back far enough? I have the wildwood proportional valve wide open. Thanks
Looking for something other than something in the lines.
Old 09-03-2016, 10:11 AM
Do you have a factory proportioning valve? It could be stuck in front only mode.
Old 09-03-2016, 11:36 AM
Wilwood and its open. Wilwood thinks I may have it adjusted to tight and it not on covering the exit but if it bleed correctly then...
Old 09-03-2016, 05:29 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Do you have disc or drum brakes rear? If drum you need a 10# residual valve.
Old 09-03-2016, 06:06 PM
Sorry C4 brakes
build site https://lateral-g.net/forums/showthread.php4?t=44704
Old 09-03-2016, 06:38 PM
andrewb70's Avatar
You would be surprise how much fluid it takes to fill new, dry brake lines...I would just crack all the bleeders and let gravity do the work while keeping an eye on the fluid level in the MC...
Andrew
Old 09-03-2016, 06:44 PM
Vega$69's Avatar
I have good luck with a vacuum bleeder. Also have a Motive pressure bleeder but doesn't fit the Wilwood master.
Old 09-03-2016, 07:26 PM
thanks gravity is one of my options
Old 09-03-2016, 08:36 PM
dhutton dhutton is online now
I have had good luck with a Phoenix reverse bleeder. You push fluid from the calipers back to the master cylinder.
Old 09-04-2016, 09:54 AM
bretcopsey bretcopsey is offline
I went this route when going through my son's truck, except did the homemade route to save some money. Worked like a charm.
