Old 01-27-2016, 09:44 AM
TheShopLLC.com TheShopLLC.com is offline
Originally Posted by 68LS1 View Post
Any update on 2nd Gen kick panels and parcel shelf?
Nothing as of yet. Shop is full of Chevelles. Possibly mid year.
TheShopLLC.com
Old 06-20-2016, 09:58 PM
Chicken Louie's Avatar
Chicken Louie Chicken Louie is offline
Default Hi beam switch
Clint, Do you guys move the high beam switch a little to get the kick panel to clear? I know the factory parking braket gets trimmed. Thank for the photos your stuff looks awesome
Old 06-28-2016, 06:27 AM
Thanks for the good words!! Some guys have been removing the old style foot switch all together. Panel should pop right in with foot switch.
TheShopLLC.com
Old 09-15-2016, 09:45 AM
ADY's Avatar
ADY ADY is offline
Installed the kick panels in my '68 Camaro and they look great the speakers sound awesome as well.
Below is my feedback on my install:
  1. Definitely have to notch the bottom of the stock e-brake bracket.
  2. Works with the factory high beam switch, but very tight. I put a few washers under one side to angle the switch away from the panel.
  3. I took off the double sided tape for the speaker covers and used velcro instead so I don't risk breaking the cover when i have to remove the panel in the future.
  4. At least for my 6.5" speakers the cutout in the panel wasn't big enough to allow me to install them after installing the panel, so I'd recommend enlarging the cutoff as much as possible.
  5. I had to cutout a small piece from the top of the panel b/c it was hitting dash support; didn't like I had to do this after the panel was already wrapped, but at least the rough edge isn't noticeable.
-Adam
1968 Camaro SS
Old 10-08-2016, 07:28 AM
DT69Cam DT69Cam is offline
Adam, can I ask you a question (off topic) ? What rubber sleeve did you use for the clutch rod going through the firewall ?? I have the McLeod hyd set-up and was looking for something to go over the rod and cover the hole. Thx man.
69 Camaro Convertible (LS3/TKO in the works)
Old 10-08-2016, 08:44 AM
ADY's Avatar
ADY ADY is offline
Sorry, bought the car with the T56 already installed. I'm fairly certain the whole clutch setup was sourced from Hurst Driveline, so might try calling their tech support line. Looking at the invoice, the master cylinder part# was T75-750U.
-Adam
1968 Camaro SS
Old 10-08-2016, 10:03 AM
Thank you!!!
Old 11-14-2016, 02:35 PM
Awesome install and love the feed back! Thanks a ton!
TheShopLLC.com
Old 11-23-2016, 06:41 AM
Default 20% off till Monday
http://the-shop-llc.myshopify.com/pr...ro-kick-panels
TheShopLLC.com
Old 06-19-2017, 01:39 PM
Be sure to check out our online shopping cart with all the latest and greatest on audio combos. Call us up with any questions at 954-440-0251 Thanks a ton!
https://the-shop-llc.myshopify.com/collections/all
TheShopLLC.com
