Old 12-04-2016, 12:34 PM
aany001's Avatar
aany001 aany001 is offline
Default Front coil over spec
Hey Guys need some Help........I have a 69 Camaro 18" wheels LS and T56 with stock front subframe with QA1 front coil overs. What coil weight and length should I be running? It now has 350LBS 10" coils and rides real firm. Wonder if I can smoothen it up a bit. What do you guys suggest?
Steve
Old 12-05-2016, 09:24 AM
BMR Sales's Avatar
Steve, if you had bought them from us, that is the combo I would have suggested
Old 12-05-2016, 10:02 AM
Rod P's Avatar
Rod P Rod P is offline
Steve
350 I think is actually very light, is it firm because the shock setting is stiff? or is the spring so soft that the collar is tightened all the way up to keep ride height and now creating coil bind and the making the ride rough
are the arms stock? stock arms have a terrible motion ratio and I think require more spring
what LS? a cast iron truck block is heavy and that T56 weighs a ton, I would have started you at 550 lb spring from QA1 (spring weights from different companies work differently)
hope this helps
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 12-05-2016, 11:25 AM
ADY's Avatar
ADY ADY is offline
I have Art Morrison subframe and C6 control arms with T56 and SBC and I have QA1 12" rated at 500lbs and Strange adj. shocks. Definitely not a smooth ride on city streets, but about what I expect considering the ride height.
-Adam
1968 Camaro SS
Old 12-05-2016, 02:52 PM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
What he said.
Depending on the motion ratio, it really varies but 350lb sounds very light on a coilover. For example, with our control arms and their motion ratio, we run a 650lb for a street/daily driver feel.
The firmness that you're experiencing could be cause by coil bind, shock bottoming out, etc.
Old 12-05-2016, 07:13 PM
aany001's Avatar
hope this helps
Rod I'm running speed tech tubular upper and lower control arms. Its an all aluminum LS1. What I did notice when I took the suspension apart was my lower control arms are really hard to move up and down. Could I have the lower arms too tight? Also I originally Had the adjustment all the way to the firmest setting. I backed it off and it rode much better. Reason why I'm all over this is because I'm replacing my lower ball joints and wanted to double check what coils I have in there. I gave QA1 a shout today and they recommended running the 350LBS springs. Not quite sure what to do at this point lol. Thanks for the help guys!!
Old 12-05-2016, 07:19 PM
aany001's Avatar
Originally Posted by Josh@Ridetech View Post
What he said.
Josh I'm in the middle of installing your 4 link in the rear and so far I'm extremely impressed with your product and customer service. I would love to match my front to my rear suspension but with our dollar its just not in the cards this year.
Old 12-06-2016, 06:47 PM
aany001's Avatar
Posting a couple pics showing what the adjustment is at for the ride height I want. The ride height was perfect with the front tire just tucking into the fender
well. Do you guys think the adjustment is cranked up too much to achieve the ride height I'm after? At this adjustment the coils had around 1/2" between each other.
Old 12-06-2016, 09:04 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
I tend to agree with Rod, I would expect to be running a much heavier spring say in the 500 to 600 range. That said, you should be able to adjust the ride quality with the shock adjustment.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 12-07-2016, 09:25 AM
Blake Foster's Avatar
i would have sold you 550 lb springs for that combo.
just to ad gas to the fire. i think 350 is too light and agree with Rod that you then need to adjust the compression way up to have the car not bottom out.
Blake Foster
www.speedtechperformance.com
