Old 01-16-2017, 08:19 PM
gnx7's Avatar
gnx7 gnx7 is offline
Default Which LSD unit for 9" road race setup....
I have a Detroit Locker in my 35 spline Ford 9" setup 3.25 gears for the Chevelle.
I've been made aware I can put lighter springs in the Detroit Locker; however am leaning towards a WaveTrac LSD.
What are people running out there? I know my options are a little limited with the 35 spline axles.
This will be a 75% street/25% track car. Some AutoX as well... mainly road racing. The WaveTrac lifetime warranty is appealing... and I run one in my LS9 turbo RX-7 with solid 8.8" which is around 1400hp.... but that is only 2900lbs (without driver). No issues in a couple thousand very hard miles on it.
What LSD unit is Mark Stielow running in his creations?
Old 01-17-2017, 10:21 AM
dontlifttoshift's Avatar
dontlifttoshift dontlifttoshift is online now
We have had good luck with the Strange S Trac in 35 spline. The helix angle on the gears is higher so the bias ratio is higher than a wavetrac.
Donny
Old 01-19-2017, 04:52 AM
71RS/SS396's Avatar
I didn't have good luck with the wavetrac, it didn't even make it through 2 events.
Old 01-21-2017, 08:02 PM
gnx7's Avatar
Thanks for sharing.... any others?
Old 01-24-2017, 07:02 AM
Air-bender Air-bender is offline
Mark has used C&R Racing for rear gear. The TrueTrac unit they offer is about 3K which included REM and dyno break in.
Old 01-28-2017, 10:07 AM
gnx7's Avatar
$3K is a little more than I want to spend on this sucker! Will keep it in mind.
