Old 01-31-2017, 09:59 AM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Originally Posted by will69camaro View Post
Gave up on the headliner sadly. Just wont fit over the roll bar. Will be sold and I'm going with a conventional style roll bar.
Small update. Got the headlights installed and wired up, horns wired up too. Need a hub puller so I can hook up the turn signal arm to ensure those work, and to hook up the horn button. May try to get that tomorrow, as well as a few other things.
Now to pics!
Headlights installed.
Horns Installed.
Wired up the lights and installed some front paneling (header panel). Pushed it out of the garage for a bit of sun, and to clean the garage as it has become a mess again!
Let there be light!
Light gives off a pretty decent pattern.
Low Beam
High Beam
Started on the carpet also!
More to come tomorrow!
Awsome build man. Just wondering where you purchased the lights from. Did they come with relay and wiring kit as well?
72 Camaro RS:SOLD
68 Camaro:
Old 01-31-2017, 03:04 PM
Originally Posted by ryanleiker View Post
What's your instagram?
Same as here. IG: Will69camaro
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 01-31-2017, 03:07 PM
Lights are from Amazon, they're Trucklite 27270C I believe is the part number. Wiring is factory, plugs directly into factory harness. The lights do stick out past the bezel a bit. I find it's less noticeable with the bezels that have the chrome surround.
I am not running them through a relay currently. They run 1.80amp (low beam), 3.60amp (high beam), so the switch is rated for well above that. No issues so far but haven't used them too much yet either.
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 01-31-2017, 08:22 PM
Zoomin Zoomin is offline
Will, did the headlight buckets need to be modified much to get the lights in there?
1964 Lemans
1966 Skylark
1969 Camaro
Old 01-31-2017, 09:20 PM
None at all. Mod if you want to bring them back or further in. I didn't bother.
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 02-01-2017, 12:18 AM
72Z/28's Avatar
Thanks for the quick reply. I went a head today and placed an order of the trucklite 27270C headlights.
Also regarding the momo steering wheel, did you go with 320mm or 350mm size?
72 Camaro RS:SOLD
68 Camaro:
Old 02-01-2017, 06:30 AM
JohnJ@RideTech's Avatar
JohnJ@RideTech JohnJ@RideTech is offline
Coming along nicely!
Old 02-01-2017, 08:34 AM
Sorry for the delay. It's a 320mm.
https://www.amazon.com/Momo-RCE32BK1.../dp/B00PY3J7IY
Thanks!
Driveshaft has been dropped off to be shortened slightly. Will be ready tomorrow, will re-install, change rear springs out as i'm maxed on existing ones and still settling here and there.
Glass install is ongoing. I need to get after it and get that finished. Waiting on a couple small misc parts to show up for door weatherstripping.
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 02-04-2017, 08:56 PM
Cars and coffee today was good. Still no sideglass so I stuck by the car the entire time.
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 02-04-2017, 09:12 PM
rickpaw rickpaw is offline
Car looks good Will. Were you at Memorial City mall cars and coffee?
Tu Ho
