Old 10-30-2006, 04:04 PM
GHOSTDANCER GHOSTDANCER is offline
Thumbs up
Looks sharp
Old 11-05-2006, 01:49 PM
James OLC's Avatar
Default Thank you ATS!
I wanted to take a minute to thank Tyler, Shane, and Russel from American Touring Specialties for a great time at the SEMA show. Despite scrambling to finish moving in on Monday they were kind enough to invite us over and give us a tour of their shop.
ATS simply rocks - their people, products, and services are top notch and I recommend that anyone who has the chance should give them a call and check them out (if they have not already).
For those of you who were not able to make the show here are a couple of pictures of the sub that they had in their booth. Thing to note include their new coil over conversion, their new Sidewinder serpentine setup for LSx engines, their new carbon fiber LSx valve covers, not to mention their killer headers, power steering box and T56 coversion kit.
Thanks again,
James
At first look there is so much to take in:
First and foremost is ATS’s new Sidewinder Accessory Drive
The Kinsler injection looks perfectly at home.
The reworked shock mount to accommodate the coil over shocks and springs.
The upper mount was modified slightly from the original design for additional strength and stability:
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 11-05-2006, 01:50 PM
James OLC's Avatar
And a couple more...
Penske dual adjustable shocks with remote mounted canisters mounted on the subframe for easy adjustment:
The whole thing is like a work of art.
Remote CV oil filter mount and huge filter should be perfect with the LS7.
The AFX spindles have been fitted with 3” race studs.
Great work ATS – absolutely first class design and fabrication.
James
1969 Camaro - Dusty
Old 11-05-2006, 02:20 PM
68RS350 68RS350 is offline
Do you have any idea how much and when that serpentine set up will be available? I like that its not polished up and is black. I dont like the polished look and i havent found a serpentine set up that isnt polished. Also when is the coil over kit going to be available? Im in the market for one also. Thanks
Old 11-06-2006, 02:11 AM
ATS is coming strong! Excellent details !!
63 Z06
Old 06-17-2007, 09:23 PM
James OLC's Avatar
Default OneLap Camaro Update - June
We are making headway on the OLC Camaro.
The roll cage is in:
Size:  34.5 KB Name:  cage 8.jpg
James
1969 Camaro - Dusty
Old 06-17-2007, 09:25 PM
James OLC's Avatar
Size:  39.9 KB Name:  cage 4.jpg
Size:  53.3 KB Name:  cage 5.jpg
James
1969 Camaro - Dusty
Old 06-17-2007, 09:31 PM
James OLC's Avatar
The Tilton Pedal Assembly is in and thanks to the custom steering column that Ididit Inc. built for us, the ATS Lee Engineering power steering box is good to go:
James
1969 Camaro - Dusty
Old 06-17-2007, 09:32 PM
James OLC's Avatar
James
1969 Camaro - Dusty
Old 06-17-2007, 09:33 PM
James OLC's Avatar
And the rest is coming together as well
James
1969 Camaro - Dusty
