03-07-2017, 04:45 PM
AC compressor fittings
I'm looking for the part that bolts to the ports on the AC compressor for an LT1 out of an Fbody. I need one that comes off the sides and not out the back like stock. Anyone have any idea where I can look and what the proper name for that piece might be?
03-07-2017, 05:57 PM
Pretty sure it is called a manifold. I have seen various ones on eBay.
Or something like this:
http://www.ebay.com/itm/R4-A6-A-C-Co...-/401022120297
03-07-2017, 06:50 PM
Manifold sounds like it might be correct. Thanks for the link too, Don. That may be exactly what I need. I'll contact them and find out.
03-07-2017, 07:09 PM
Are you trying to use a stock lt compressor?
Do you mean a compressor block adapter?
http://www.jegs.com/i/VPA/960/045024...FdY6gQodqzsGlg
03-07-2017, 07:13 PM
Yes, the aftermarket options for changing the accessory brackets out are ugly in my opinion, and I'm not aware of anyway to mount an alternative compressor like a Sanden in place of the factory unit.
I found that piece, too. I think it may be the same one Don linked to only from a different source. I'm emailing Vintage Air now to see if it will fit. It's listed as working with A6 compressors but technically mine is an HD6 compressor.
Thanks Kevin
03-08-2017, 10:37 AM
Vintage Air wrote back and said it should work for me. I'll give it a shot and find out. Thanks for the help!
