Old 03-13-2017, 07:42 PM
Heather1124's Avatar
Heather1124 Heather1124 is offline
Boy was I excited when this showed up!
I laid out my suspension parts so I didn't forget about anything.
Name:  all suspension parts.jpg
I like the way the front suspension came together! I still need to install the shocks and front sway bar.
Name:  front suspension1.jpg
Size:  252.8 KBName:  front suspension2.jpg
Then I started working on the new rear. I discovered even after drilling out the holes on all the brackets to 5/8", the u bolts didn't quite line up. The holes on the brackets would line up for a 3" inside diameter, but the u bolts I got in the Hotchkis kit were a little bit bigger diameter. So I spent quite a while with the die grinder until I could get them through all the holes. I think it turned out pretty nice.
Name:  Rear end brackets.jpg
Then the heavy lifting came when I started installing the new leaf springs. I'm glad that part is over, but I really like the way it looks so far!
Name:  Moser rear with leafs1.jpg
Size:  219.0 KBName:  Moser rear with leafs.jpg
Next weekend I'll install the new bushings in the rear frame rail and start bolting the rear in.
Old 03-13-2017, 07:50 PM
Zoomin Zoomin is offline
Lots of nice goodies there! What ratio did you order?
Be sure to tighten up the sway bar end links when the car is sitting on all 4 wheels.
1964 Lemans
1966 Skylark
1969 Camaro
Old 03-13-2017, 07:58 PM
I went with the 3.73 with the Truetrac differential. It's a good thing I just got my bonus at work to replenish the bank account!
There will be lots of tightening when it's sitting back on the ground. And probably a double or triple check on everything before it goes out the door for the first test drive!
Old 03-14-2017, 02:29 AM
fleetus macmullitz's Avatar
Congrats on your progress Heather.
Another SBC fan here.
How's the weather there now for working on the car?
Old 03-14-2017, 05:32 AM
Thanks for the support!
After a winter of more moisture than I'm used to, we've finally had some really nice weather. Two weeks ago it was highs around 30, now we've been 50s-low 70s for almost two weeks. The nice weather came just in time to keep my schedule on track to paint the interior next month.
Old 03-14-2017, 10:46 AM
jwcarguy jwcarguy is offline
Banned
Looks great Heather!
Keep up the great work!
Jeff
Old 03-14-2017, 07:15 PM
Jeff
Thanks Jeff!
Old 03-15-2017, 11:19 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Heather I am really impressed and excited to see all the progress. You aren't messing around. I gotta admit, I want to drive this car when it's done. I have zero doubt it'll be a blast to drive.
Super glad you decided to go this route.
Curtis
Old 03-15-2017, 06:39 PM
Thanks Curtis! The further I get into the project the more excited I'm getting.
I keep thinking that I should bring it down that way when I've got it all together. Actually meet you and Jeff and show off my work!
Old 05-29-2017, 06:32 PM
Spiffav8's Avatar
Lateral-g Moderator
Heck yeah you should! We would have to grab everyone we know in town with a hot rod and cruise a little. Maybe stop off somewhere for some tacos!
Curtis
