Old 07-18-2017, 08:38 AM
WILWAXU WILWAXU is offline
Thumbs up
It's been fun watching this one come together. Great work!
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 07-18-2017, 09:56 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Originally Posted by ironworks View Post
We actually did not remove the cowl or fresh air vents from this car. Its a pretty standard Rain Gear wiper system install.
I meant since the rain gear is fitted from inside the car as the upper cowl has close out panels welded in, how did you keep water from running into the interior of the car? Looks like you made black plates that may have a gasket sandwiched in between?
Old 07-18-2017, 10:02 AM
ironworks's Avatar
We smoothed the cowl. I forget we had to remove the air passage to make enough room for the EPS, and ECU and all the other crap under the dash.
http://www.ironworksspeedandkustom.c...rod/prd510.htm
Old 07-18-2017, 02:33 PM
JON Q's Avatar
JON Q JON Q is offline
Since the LT4 uses an electric power steering, how did you get it to work? Or did you use a hydraulic based version?
Old 07-18-2017, 02:59 PM
ironworks's Avatar
We went with electric power steering that was from Unisteer that used an ididit column.
Old 07-18-2017, 05:16 PM
JON Q's Avatar
Thank you!
