Old 07-24-2017, 10:37 AM
Default 1st gen Camaro ECU mounted under dash
Hi Has anyone got pictures of their ECU mounted replacing the glove box or anywhere under the dash for a first gen Camaro?
Thanks in advanced.
Wayne
Old 07-24-2017, 01:34 PM
Z06vette's Avatar
Z06vette Z06vette is offline
I used to mount them above the glove box, even with vintage air. I am not sure if I have a pic though. I'll have to look. I now go thru the trans tunnel just inside the firewall on pass side. The newer, smaller ecms fit well on top of the trans tunnel between the evaporator and the firewall. I do have pics of that on a first gen f body.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 07-24-2017, 03:40 PM
We just started looking for a good place to put it and I know a lot of guys put it above the glove box or right where the GB door is. Both seem pretty good spots.
Old 07-24-2017, 03:42 PM
I put the 5th gen console in and I want to make a gauge pod for my gauges. I sort of went crazy buying them.lol
Old 07-24-2017, 05:42 PM
I made a glove box and mounted my Holley dominator on top of it. And the fuse panel inside it.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 07-24-2017, 06:06 PM
I just checked the pictures, thanks it looks good.
Old 07-25-2017, 10:25 AM
ragz ragz is offline
Here's mine , 67 camaro, vintage air , its tight but easily do able.
Old 07-25-2017, 12:54 PM
That's the way I'm leaning towards mounting my ECU and panel. The 67 has a taller glove box door than a 69 so my ECU will be covered at the top but once its in it will be good. Thanks!
Old 07-25-2017, 03:11 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Jeff (JWCARGUY) mounted his where the firewall meets the trans tunnel and it's covered by his 5th gen console. Very easy to get to if need be. Might be worth a PM to get a few more details on that and how he setup his console with the gauges.
Curtis
Old 07-25-2017, 06:24 PM
Thanks Curtis, I can add that to asking if he posted the build of his gauge pod. Thanks for suggesting it.
