Old 06-29-2017, 07:35 PM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by NAPA 68 View Post
Mark,
If you can elaborate (at this point), what you did for the fuel system? Additionally, does the FED fit into the subframe any better than your experiences with the LS7 / 9 combo?
Looking forward to seeing more. Always enjoyable to follow your builds.
Tim
The fuel system is fairly easy. The GM crate engine harness comes with a fuel engine pump controller. Use a Gen 5 ZL1 fuel pump in a Ricks tanks and your done.
On the FEAD we are using a Holley adaptor for the A/C. Then the DSE subframe need notched a little bit
Old 06-29-2017, 07:38 PM
Stielow's Avatar
The fuel system is fairly easy. The GM crate engine harness comes with a fuel engine pump controller. Use a Gen 5 ZL1 fuel pump in anRicks tanks and your done.
Originally Posted by PTAddict View Post
Mark,
Great build again. I'm working on my own LT4 upgrade, on track for later this summer. Did you change out the supercharger for the 2017 version, or just the lid? And any hints as to what you did for that power steering pump?
Thanks, Scott
The GM crate engine is a 2016 based engine so the old bricks and lid. Once I know my power steering system works I'll post the details.
Old 07-05-2017, 04:38 AM
momsnova momsnova is offline
The LS 7 pan and the dry sump LT4 pans are very close so from that data I would say the LT4 dry sump pan will not fit the stock Fist Gen Camar subframe. But, Holley is doing a LT wet sump pan that should fit.
Mark, thanks for the info! I read the Super Chevy articles online and personally it's good to know Sled Alley, Holley and yourself are working on solutions to simplify an LT based swap. The LT-4 is hard to beat for the
Shane Knight
1970 Nova 502 TH400
Speedtech/Ron Sutton Front Suspension
Old 08-27-2017, 05:48 PM
Stielow's Avatar
I finally got this car running.
The LT4 runs great. Lots of power easy to drive.
Still some issues to refine, but overall it is a great car.
Mark
Old 08-27-2017, 06:48 PM
Build-It-Break-it's Avatar
Any close ups of it? Interior,engine bay,brake set up etc?
Ahmad B
Old 08-29-2017, 05:46 AM
Stielow's Avatar
http://www.superchevy.com/how-to/pro...t-1969-camaro/
http://www.superchevy.com/how-to/cha...nsion-upgrade/
http://www.superchevy.com/how-to/eng...-camaro-build/
http://www.superchevy.com/how-to/eng...a-1969-camaro/
Old 08-29-2017, 03:29 PM
preston preston is offline
Excellent.
I love the OEM look and feel, no one does it like you.
Building this all under good patina is my dream car come true.
Appreciate all you share, even if I'm not a GM guy.
Old 08-30-2017, 08:05 AM
randy randy is offline
how do you like the ultimate headers? If i ever switch i might go with them. Im using stock position mounts though and i didnt know if the steering column shaft would interfere.
Old 08-30-2017, 07:01 PM
YAMATHUMP's Avatar
YAMATHUMP YAMATHUMP is offline
Originally Posted by OLDFLM View Post
I still want you to do a 2nd gen...
You and me both!
Brad
83 Chevy c10
Old 08-30-2017, 07:23 PM
Ed.Capen's Avatar
Ed.Capen Ed.Capen is offline
Good Guys
Mark
Looking forward to seeing this on the Hall of Fame Tour Next month...
Looks to be a lot of camaro's going this year.
Goodguy Ed
[SIGPIC][/SIGPIC]
