Old 09-22-2017, 07:58 PM
novahollic's Avatar
novahollic novahollic is offline
Default LSA in a Chevelle, looking for ideas on intercooler tank
I am dropping a LSA into a 71 Chevelle, and I am trying to figure out a way to incorporate an intercooler tank under the hood. The LSA normally doesn't use one, but I would like the extra capacity and ability to add ice if/when the car goes to the drag strip.
As of now, the battery is still in the factory location. It probably won't move to the trunk, since there is a pretty elaborate stereo setup in there. I was thinking about fabbing a tray behind the driver side headlight and running a Canton tank made for a battery tray. This idea, however, takes up most of the room that the air intake tube is going to go.
Has anyone done this swap that would be willing to share pictures? If it just plain doesn't work out, I can run it the way they do in the gen 5 ZL1 without the tank, but I would really like one if possible.
Old 09-22-2017, 08:40 PM
Mine in my Camaro is on the right side behind the head light where the battery was. You will need a place to fill it as your highest point. if you are using the factory size hoses yo could use the factory fill. I had a tank made to fit, and used an aluminum sheet for it to sit on.
Old 09-25-2017, 05:14 PM
andrewb70's Avatar
Why not make a tank that mounts in the empty space behind the passenger side wheel well and the firewall? Presumably the firewall is smooth and all you have are some hoses going through the firewall in that area.
The less weight hanging forward of the front track the better.
Andrew
Old 09-25-2017, 07:13 PM
novahollic's Avatar
Yeah, I would love to use the battery area, but I have to keep the battery there.
Andrew
Thats a good thought. The firewall is smooth, and the A/C and heater lines are run through the fenderwell. I would have a good amount of space to put a tank. I guess I'll put the inner fender back in to get a visual.
Thanks for the thoughts guys.
Old 06-12-2018, 04:59 AM
cantcatchmitch's Avatar
cantcatchmitch cantcatchmitch is offline
http://www.superchevy.com/features/1...t-to-move-out/
in this article you can see i used a 1 gal fuel cell that i cut and added fittings to as a reservoir for our lsa.
difficult takes a day, impossible takes a week.
Old 06-14-2018, 10:41 PM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
We've done a couple cars with tanks we fabbed up in this location. Understood you haven't moved your battery, but thought I'd share!
-Dale
SchwartzPerformance
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 06-15-2018, 06:16 PM
Bmf5150 Bmf5150 is offline
I built a tank on my 68 Camaro to sit under the radiator ,it’s 2 gallons
Old 06-15-2018, 06:53 PM
Friends 72 in my shop.
Old 06-18-2018, 09:25 PM
This guy built mine custom . https://www.facebook.com/paul.revaitis
here's a picture
