Old 09-25-2017, 11:35 AM
V8TV's Avatar
V8TV V8TV is offline
Driveshaft loop
These parts will become a removable “kicker” from the transmission crossmember to the frame.
Notching the tube with an HTP tubing notch tool.
The transmission crossmember fully welded
And the whole rig fitted up in the car with the exhaust.
Planning the rear tube exit over the axle.
Kevin Oeste
V8 Speed and Resto Shop
V8TV
Muscle Car Of The Week
V8 Radio Podcast
All about us:
https://www.v8speedshop.com
Old 05-02-2018, 12:54 AM
CRCRFT78's Avatar
CRCRFT78 CRCRFT78 is offline
Its been a while, are there any updates on this build?
Jose
Old 05-02-2018, 06:55 AM
V8TV's Avatar
Sure, I'll see if I can post some big updates later this week. Thanks for asking!
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
The Following User Says Thank You to V8TV For This Useful Post:
Nonhog (05-03-2018)
  #74
Old 05-18-2018, 11:10 AM
CRCRFT78's Avatar
Where are those updates Kevin?
Jose
Old 05-18-2018, 01:14 PM
V8TV's Avatar
This is a fuel-injected car, so we used a reproduction stock fuel tank from Tanks, Inc., and installed one of their in-tank fuel modules for the pump.
The module allows for an in-tank EFI pump to be mounted in nearly any kind of tank, as the depth is adjustable to the tank.
Here, the pump module and level sender are sealed to the tank and bolted tight. One fitting is pressure, the middle is for the fuel vent, and the other is a return.
Meanwhile, the Vintage Air hoses, condenser, and other items are installed as wiring begins.
Much of the plumbing and wiring will be hidden, but the goal was more to make the underhood area clean and not to hide absolutely everything.
Vintage Air Gen IV evaporator unit being installed under the dash.
An American Autowire Classic Update harness replaces all the old wiring.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 05-19-2018, 02:44 PM
CRCRFT78's Avatar
Looking good Kevin.
Jose
Old 06-08-2019, 09:33 PM
CRCRFT78's Avatar
Any updates on this one?
Jose
Old 06-10-2019, 09:03 PM
Yeah any updates!
Old 06-10-2019, 09:18 PM
V8TV's Avatar
Yeah, we've got some updates. Let me get something together and I'll post 'em up.
Thanks for asking!
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 10-06-2020, 02:45 PM
65 Impala SS 65 Impala SS is offline
Default Finished?
It looks like this car is finished on your website? Can we get some detailed pics?
