Old 02-16-2018, 07:29 AM
TorqStorm's Avatar
TorqStorm TorqStorm is offline
Originally Posted by f100matty View Post
Do you have to change the compression ratio on a stock 351C with closed chamber heads for the torquestorm with it being so high stock?
There are a number of different variables that play a part in boosting your application. Cam profile, fuel type, compression, designated use of the vehicle etc. I believe your setup is around 11:1? Typically we would suggest around 9:1-9.5:1 for roughly 8-10# on your engine. Boost will raise that compression ratio.
For example an 11:1 engine with 8# of boost at roughly 600 ft above sea level is going to put you around 16.9:1 compression.
Feel free to email our sales staff, they are great at helping out the customer with their build.
[email protected]
Torqstorm
[SIGPIC][/SIGPIC]
www.torqstorm.com
Old 02-19-2018, 06:21 AM
TorqStorm's Avatar
Here is Rick Lewis's 70 camaro with a blown small block.
[SIGPIC][/SIGPIC]
www.torqstorm.com
Old 02-20-2018, 06:44 AM
TorqStorm's Avatar
Here is a Pontiac for you
[SIGPIC][/SIGPIC]
www.torqstorm.com
Old 02-20-2018, 07:12 AM
Interceptor5588's Avatar
Interceptor5588 Interceptor5588 is offline
Thanks! Any idea of the engine specs, and what HP results from your setup?
70 GTO
92 Formula
Old 02-20-2018, 09:47 AM
TorqStorm's Avatar
This is a customers car, it is a mild 400. Not sure on the output. But our supercharger should have no problem making 40-50% gains on an application like that. We have made 670hp on a 383 chevy. A gain of 200+hp over na
Torqstorm
[SIGPIC][/SIGPIC]
www.torqstorm.com
Old 03-20-2018, 06:11 AM
TorqStorm's Avatar
Here is our newly revised 351 Cleveland kit mocked up.
[SIGPIC][/SIGPIC]
www.torqstorm.com
Old 04-23-2018, 11:01 AM
TorqStorm's Avatar
Our ls3 5th gen kit is finished
[SIGPIC][/SIGPIC]
www.torqstorm.com
Old 04-26-2018, 07:54 AM
TorqStorm's Avatar
Here is a dyno sheet of a customers ls2 with our supercharger kit.
Modifications:
Ls2 Sbe
ported 243 heads
228r camshaft
fast 102 intake
Torqstorm ls conversion kit at only 8#
Contact us at
[email protected]
616-706-5580
IG: @torqstorm_superchargers
Facebook: Torqstorm Superchargers
[SIGPIC][/SIGPIC]
www.torqstorm.com
Old 05-24-2018, 08:26 AM
TorqStorm's Avatar
The drift car from ls fest west
[SIGPIC][/SIGPIC]
www.torqstorm.com
Old 07-16-2018, 11:03 AM
TorqStorm's Avatar
Some more customer vehicles
[SIGPIC][/SIGPIC]
www.torqstorm.com
