Old 03-27-2018, 09:23 PM
FETorino's Avatar
FETorino FETorino is offline
Do you have any wing pictures Greg. Ron is holding out on us.
Sweet rack by the way.
Ron
Will the wing be a top mount or traditional bottom mount? Will the uprights be rearward of the rear bumper or come up through the rear deck lid?
For the three link are you using the shock style decoupled setup like Payton went to or the std kit PK started with? Will the rear link be adjustable from the drivers seat?
Rob in SoCal
Old 03-27-2018, 10:42 PM
gnx7's Avatar
gnx7 gnx7 is offline
What front spindles are you using? It is coming along nicely!
Old 03-28-2018, 08:44 AM
Ron
We have a name for people like you...... it begins with "ASK" and ends with "HOLE".......
LOL
Hey -- you're my competition! You don't expect us to spill our guts on every secret do you?? Oh! I think PICTURES work better in your case anyway you little crayon eater....
Name:  70 Mustang Track Warrior - Greg Weld V1.jpg
Old 03-28-2018, 09:05 AM
jarhead's Avatar
jarhead jarhead is offline
LOL
Attachment 65129
GW, So you are running the Stang against his Torino?
I had to get in on the fun, lol
joe
Semper Fi
My 68 Torino
Old 03-28-2018, 09:37 AM
Does he have a Torino?? Oh wait!! Yeah -- I remember now..... But I don't think that's a race car. I think it's a metallurgical study for corrosion and the speed at which iron oxide forms.
Old 03-28-2018, 09:41 AM
jarhead's Avatar
OMG, i'm in tears
joe
Semper Fi
My 68 Torino
Old 03-28-2018, 09:53 AM
gerno's Avatar
gerno gerno is offline
Ron - another question about the structure, this time the cage.
Based on pics of other builds it seems typically people use 1 piece front pillars that extend from either the main rear hoop or the roof hoop to the floor. In this build the front pillar is a short piece attaching the roof hoop and dash bar. I also notice the dash bar isn't bent but instead welded together. Without having any real knowledge of what works best I always assumed it was better to bend the steel rather than weld it together. This build seems to prove my assumptions wrong and in general this looks a bit easier than bending in tight spots. Is there any difference or benefit in strength when bending vs welding a joint?
Old 03-28-2018, 10:00 AM
I have your answer ------ I'm not crashing the car so it doesn't matter.
Old 03-28-2018, 10:11 AM
gerno's Avatar
I believe that but I assume you may let Alex and/or Rob drive at some point.....
Old 03-28-2018, 10:42 AM
Its all about placement, force direction-continuation-pathways and proper use of nodes. A straight piece of tubing will resist a bending force more so than a bent piece of tubing,even if welded. Its safe to have a bent tube but that depends on force loading, support (nodes) and directions.
The Following User Says Thank You to Vince@Meanstreets For This Useful Post:
FaBrycation (03-28-2018)
