Old 04-05-2018, 10:20 AM
Ron Sutton's Avatar
Originally Posted by Panteracer View Post
Ron,
Just noticing in the pictures that the anchor points for the upper and
actually lower a-arms are slotted. There seems to be a labeled washer
or insert that you can move the a-arm anchoring points up or down in
the slot. I assume this is a piece that holds the anchoring bolt to a
certain height... are there different height inserts or are you just sliding
the anchor bolt up and down??
I ask this because someone else doing a second gen was moving his lower anchor points up or down based on info you gave him by welding a washer
in at a certain height... seems like the race cars with slotted anchor points
let you adjust this with the slot or inserts.. kinda of a trick thing if I am
thinking right
Bob
Great question Bob!
On our Track-Warrior front clips ... all 4 versions ... the LCA & UCA brackets have slots for our slugs. When I designed each of these front suspensions, I made them so we can build them "semi-custom" for each customer, with different ride heights, frame widths, etc. I placed the slots in a location that allows me use precision slugs to optimize each semi-custom front frame & suspension.
The precision slugs are on page 188 of our catalog HERE. We have "0" slugs to put the LCA or UCA pivot in the center, and then offset slugs every 1/16" ... up to .250". This allows me to dial in the exact roll center, camber gain, anti-dive, etc I want on each front suspension.
When we're correcting the geometry in a factory frame or front clip, I don't use the slugs. It is so hard to get them right ... when we make changes ... I don't want the lower pivots to be adjusted or moved after I've nailed down where they go. So in these cases, I prefer & recommend we simply weld thick, hardened washers to the outsides of the LCA buckets ... in the correct location ... and call it good.
Ron Sutton Race Technology
Old 04-05-2018, 02:14 PM
Panteracer's Avatar
Default Weld Sutton Mustang
Thanks Ron
Now I am understanding some of the thought process
Bob
Old 04-13-2018, 12:21 PM
DBasher's Avatar
DBasher DBasher is offline
Just sayin....
Old 04-13-2018, 03:29 PM
Ron Sutton's Avatar
Originally Posted by DBasher View Post
Just sayin....
Dan Basher =
Me =
The Lateral-G Gang
Mike Tolle Welding the Headers up Today =
Rob Dickey =
Greg Weld =
Randy Chastain ... =
All of us on June 28th at Thunderhill =
The Following User Says Thank You to Ron Sutton For This Useful Post:
DBasher (04-13-2018)
  #155
Old 04-13-2018, 05:12 PM
one-off customs one-off customs is offline
Default Weld, Sutton 70 bad-ass mustang
Thought I would update some pics of the mustang, the backbone, trans mount and the header configuration on the pass side. Its TIGHT but Mike Tolle is doing an awesome job.[ATTACH]65414
The Following 2 Users Say Thank You to one-off customs For This Useful Post:
DBasher (04-13-2018), gofastwclass (04-14-2018)
  #156
Old 04-15-2018, 10:47 AM
DBasher's Avatar
What’s going on here? I understand the mount for the lift cylinder, what is the lil doodad next to it?
Old 04-15-2018, 11:38 AM
57hemicuda's Avatar
57hemicuda 57hemicuda is offline
I would guess that's a raceway for fuel/brake line and wiring that is snaked inside the perimeter chassis
Ron Schwarz
Old 04-16-2018, 07:22 AM
Ron Sutton's Avatar
Ron is on the right track.
But we don't run wires or brake lines through it. We run the 2 #8 fuel lines (Supply & Return) as well as the #6 air line for the Air Jax. Running the fuel lines in the frame is simply better protection. We use 1-3/4" mandrel bent tubing at each end of the frame rail to curve the hoses up & in ... the way we want ... to make sure they stay away from dangerous stuff.
The wiring is ran under the floor in a 1" open space between the bracing structure & the belly pan. The brake lines use special Stainless AN #3 bulkhead fittings to also route through the front dog legs & rear 2x3 crossmember ... and into the 1" open space between the bracing structure & the belly pan.
DBasher (04-16-2018)
  #159
Old 04-16-2018, 10:32 AM
DBasher's Avatar
I was thinking it might be that but then thought, why would they run fuel lines so close to suspension and a big honkin tire? I’m sure it’ll be protected.
How are the lines secured inside the rail?
Old 04-16-2018, 11:12 AM
Ron Sutton's Avatar
The fuel lines are kept away from the tires.
The hoses are secured at each end of the tubes.
