Old 05-13-2018, 07:08 AM
Gmachine1911's Avatar
Thank You all, I appreciate the positive feedback! I got my shifter hole cut and my Finch Performance gear shift boot ring mounted. Let me just say, there's nothing like working with quality parts. I ordered a different Finch shifter handle so I can get rid of the ape hanger in the pic. If it was all about function, it'd be one thing as it sits close to the steering wheel but I just can't get over the looks of it...Next to get the engine fuse box and electronic throttle pedal mounted and get the transmission VSS/backup lights, etc. wired up.
The Following User Says Thank You to Gmachine1911 For This Useful Post:
syborg tt (12-29-2018)
  #92
Old 05-15-2018, 08:08 PM
Not a whole lot of progress to report but wanted to see the inner fenders and core support on it. Removed the radiator so I could take it to PRC here locally and have some stuff rearranged for an LS engine.
  #93
Old 05-24-2018, 08:03 PM
So finally got my accessory drive kit in and had a few hours over the last couple of days to whittle away at it. I went with the Holley Mid-Mount system. I liked the fact that it had no spacers and uses the C7 style cartridge water pump; no having to disassemble the whole front end of the motor if you need to change the water pump!
I went with the black version as I like the contrast it offers. With the premium kit, you get an ATI balancer along with all the other accessories. This is a really nice peace of hardware, the fit was perfect and aside from a few minor things like chasing the powder coating from the threads on the AC compressor, it all went together flawlessly.
Once I get my radiator back from being swapped over for LS power, I can wrap up the cooling system plumbing. Also got the Vintage Air components ordered and hope to get the fuel system wrapped up this weekend...I'm dying to hear this thing run!
  #94
Old 05-24-2018, 08:08 PM
Pulley alignment is spot on...
  #95
Old 05-24-2018, 08:21 PM
jarhead's Avatar
jarhead jarhead is offline
I really like the all black, been thinking bout doing the same on mine for a couple of years now.
joe
Semper Fi
My 68 Torino
Old 05-26-2018, 07:39 PM
Got my radiator back on Friday so I was able to make some good progress today. In keeping with the theme, I painted it black with polished stainless hardware. While I had my make-shift spray booth setup, I also murdered out my Tanks, Inc. fuel tank. In the spirit of low maintenance, I decided to bedline the lower half of the tank to provide protection from rock chips, etc. as I plan to drive this thing and autocross it at every opportunity.
  #97
Old 05-26-2018, 07:44 PM
To at least add some texture in the sea of black, I also bedlined my fan shroud after it was painted... Not terribly noticeable but I try to add detail everywhere I can.
  #98
Old 05-26-2018, 07:47 PM
Shot of the fuel tank...
  #99
Old 05-27-2018, 08:56 PM
CMillwheels's Avatar
CMillwheels CMillwheels is offline
Awesome build 1911! Your car and mine are practically twins. The only difference is you are moving way faster than me!
Cmillwheels - Oregon
The Toys -
1968 Camaro
1968 C10
1969 Dodge Sweptline
2014 Porsche 911 Carrera S (sold)
2009 Corvette ZR1
Old 05-28-2018, 07:36 PM
Nice work it's looking good!
