Old 09-20-2018, 01:59 PM
gerno's Avatar
gerno gerno is offline
I have a 7/8" MC too and when first installed my brakes were not working. Issue was the pedal rod adjustment. I didn't have the rod long enough to account for the long pedal travel. I lengthened the rod and had amazing brakes. I would check that first.
Old 09-20-2018, 07:01 PM
I assume you have manual brakes too?
Old 09-20-2018, 10:20 PM
gerno's Avatar
Yes they are manual
Old 09-21-2018, 05:36 AM
jlwdvm jlwdvm is offline
The pedal rod nearly bottoms out on the brake switch mounting area. I would presume it is long enough since I can't adjust it out any further.
Old 09-21-2018, 09:23 AM
gerno's Avatar
I wouldn't assume that. I have a lot of pedal travel in my car...Can you pull the switch out and test to see if you get more brake by increasing the travel?
When I had my issues I was certain there was a huge issue with the brakes but it was all the rod.
Old 09-21-2018, 10:58 AM
SSLance's Avatar
SSLance SSLance is offline
Some don't like when I say it, but manual brakes on the street aren't ideal. They are made for the track.
Yep... I don't even like them for autocross either. They take way too long to react for my taste.
Lance
Old 09-21-2018, 11:20 AM
I can't make it any longer and still have the brake switch work properly.
