04-18-2019, 05:21 PM
And SOLD, going to live in Phoenix shortly. Time to get working on the new goodies.
05-05-2019, 12:28 PM
Get Out And Drive!
The Following 2 Users Say Thank You to rat_rod_russell For This Useful Post:
06-26-2019, 11:21 PM
06-26-2019, 11:22 PM
07-04-2019, 03:37 PM
The new front swaybar linkage test part. This is going to be important in developing the new version of my ackerman arm. But this new version will also improve steering angle at the same time. I hope to fix the last two problems with the TriFive C4 swaps with this single, mostly, bolt on kit. These linkage are included in all stages of the TriFive and Task Force frames.
There are some aspects of the linkage that are not ideal but they have to work with several items that were not there to start with. Like the large diameter of the coil springs. Then you need to take all the motions into considerations like, articulation angles, of the sway bar, and rod end but this seems to work and there was no signs of impact or binding on the rod end after driving it for a little while so I'm moving onto a slightly different shape and design that will be a bit easier to weld and build.
Later,
-Russell
08-29-2019, 01:01 PM
The Following User Says Thank You to rat_rod_russell For This Useful Post:
12-03-2019, 11:41 AM
01-03-2020, 08:38 AM
01-08-2020, 06:12 PM
Super Trick!!
The Following User Says Thank You to Goosesdad For This Useful Post:
01-10-2020, 06:52 PM
Yeah, that's really neat. Glad to see you're still plugging away at it all.
