Old 05-24-2019, 09:23 AM
paulk68 paulk68 is offline
Default Which tilton?
Going to use the Detroit speed tilton clutch master cylinder bracket. Just need to decide between the Tilton 75-750U or 76-750.any recommendations? Also is 3/4 bore good for LS7 clutch?
Old 05-24-2019, 01:50 PM
andre68's Avatar
andre68 andre68 is offline
hopefully someone can chime in who runs a similar setup, but if not.....I would fb message tilton directly with a question this specific. They're pretty responsive on fb and helped me choose the right pedal set/parts for my car.
Old 05-25-2019, 07:44 AM
dontlifttoshift's Avatar
Which throw out bearing are you using? I like a 3/4" MC with the F body throw out and an LS7 clutch.
Donny
Old 05-27-2019, 03:54 AM
Thank you! I have not purchased the throw out yet. do you happen to have a part number for the F body one? thanks
Old 05-27-2019, 12:47 PM
gnx7's Avatar
gnx7 gnx7 is offline
In my LSx RX-7 swaps we use a 7/8" bore MC. In most applications I just run the LUK '98-02 factory replacement slave. LUK LSC265B $45
