Alignment specs
07-27-2019, 05:57 AM
69lsvert
Alignment specs
Need alignment specs for 69 camaro. Stock subframe, tubular control arms and Viking coilovers. I need camber caster and toe for daily driver. Rear if needed is torque arm.
69lsvert
Find all posts by 69lsvert
2
07-27-2019, 01:38 PM
Tinker
What brand control arms? The specs can often be found on the manufacturer's website
Chris
Tinker
Find all posts by Tinker
3
07-27-2019, 04:23 PM
ilikeike
Take a look at this.
It has some daily driver specs, as well as factory and track specs.
http://www.speedtechperformance.com/...ment_Specs.pdf
The Following User Says Thank You to ilikeike For This Useful Post:
CCS
(08-06-2019)
ilikeike
Find all posts by ilikeike
4
07-30-2019, 03:44 PM
David Pozzi
My Specs:
http://www.pozziracing.com/first_gen...gnment%20specs
http://www.PozziRacing.com
The Following User Says Thank You to David Pozzi For This Useful Post:
CCS
(08-06-2019)
David Pozzi
Find all posts by David Pozzi
Linear Mode
Switch to Threaded Mode
11:51 PM
