Old 07-30-2019, 09:01 AM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Default BMR Torque Arm + 295/40/18
The 295s fit great with the BMR Torque Arm and I think even with the flatter wheel opening on your Camaro they would work if you look at how far inside the wheel lip the tires are tucked on my car. There's also good clearance before the tire would contact the rear of the inner wheel well on the inside. Early Firebirds don't have the seat belt bludge in the front of the inner wheel well but if your Camaro does a BFH should easily adjust for any needed clearance there.
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 07-30-2019, 07:42 PM
vstol vstol is offline
Thanks this really helps how do you like the setup? I spoke with BMR today and they are pretty much saying what you are and a mini tub even better. Did you keep your C-clips or go with a C-clip eliminator? I assume the stock gas tank still fits.
Old 07-31-2019, 08:35 AM
OLDFLM's Avatar
Default 10 years on BMR
Stock rear end upgraded 31-spline axles, posi, KORE3 brakes, etc.
Stock Goodmark replacement tank... 3" exhaust cleared everything... 2.5" tailpipes would be even better/easier.
I LOVE the ride with the BMR torque arm and their uppers/lowers and sway bar up front! I have AFCO coilovers front and rear... the ride is very compliant and comfortable, yet also very solid with great traction and cornering. I think it's the best of everything honestly!
You'll find other threads where the torque arm and 3/4-links are compared and for a dual purpose street/track car most all agree that a torque arm is the way to go...
My 2 cents. HTH
FREEDOMBIRD
Old 07-31-2019, 12:32 PM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
vstol, thank you and your family for service and sacrifice.
I like the direction of your build and I have one suggestion or actually more of a pet peeve of mine would be to complete the rest of the front RS "split bumper" front end (U+L headers and endura nose and grills) or go back to a std front bumper. I guess it was bought like this, good looking car otherwise, I guess I'm a bit of a purist
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
Old 07-31-2019, 07:03 PM
Stock rear end upgraded with C-clip eliminators, 31-spline axles, posi, etc.
My 2 cents. HTH
Old 07-31-2019, 07:05 PM
No purist here as you can see from my other builds. Do you have a picture of what you are talking about?
Old 07-31-2019, 07:10 PM
My 2 cents. HTH
with the c lip eliminaters what brake set up did you use?
Old 08-01-2019, 10:05 AM
OLDFLM's Avatar
Default KORE3 Brakes
One call to Tobin at KORE3 and you'll be set!
I've been running his manual C5/C6 hybrid setup front and rear with a Wilwood master cylinder.
FREEDOMBIRD
Old 08-01-2019, 08:50 PM
rixtrix1's Avatar
rixtrix1 rixtrix1 is offline
C-clip elininators are really just for drag racing as the bearings are really too small for any serious corner carving. Every one I've seen or serviced leaked from the kit to axle o-ring. Even standard "ford-type" bearings are really not very long lasting, especially if you plan on a lot of miles. JMO
Ric
Old 08-02-2019, 06:54 PM
great thanks
