Old 08-20-2019, 01:37 PM
68454RS's Avatar
68454RS 68454RS is offline
Default Single leaf car/Multi leaf housing
I'm in a jam and might be having to move very soon. I have a 12 bolt that came out of a multi leaf car and I want to put it in my single leaf car to avoid having to pack/haul etc.. So, as you know, the depth of the spring perchs are about 1.5"-2" different (eyeballed, I have not measured yet)
Is there a "block" / "Spacer" that would suffice to do what I want until I get settled in to the new place?
68 Camaro
Old 08-21-2019, 06:43 AM
rickpaw rickpaw is offline
Detroit Speed makes a mono leaf to multi leaf conversion kit.
https://www.detroitspeed.com/1967-19...ion-kit-041101
Tu Ho
Old 08-22-2019, 12:02 PM
redfire69's Avatar
I think the DSE part is for the other way, mono to multi-leaf spring. I would just use a lowering block to take up the space like this one:
https://www.summitracing.com/parts/afc-20246
Ron
69 Camaro Redfire
The Following User Says Thank You to redfire69 For This Useful Post:
68454RS (08-23-2019)
Old 08-22-2019, 12:09 PM
You're right. I read that wrong. But now he has options.
Tu Ho
The Following User Says Thank You to rickpaw For This Useful Post:
Old 08-23-2019, 06:44 AM
68454RS's Avatar
Yep, The DSE kit is opposite what I need. I picked up a couple 1" blocks and will place them under the spring between the spring and lower shock mount plate. This should get me by until I get settled without lowering the car any.
