Old 11-26-2019, 06:05 PM
billohio billohio is offline
Default Mounts for LSA in first gen Camaro
I am getting some parts around to put a LSA in a first gen camaro. I have read the post where my stock frame will need to be notched for the a.c. compressor. I wondered if anyone here that has done this swap, what did you use for motor mounts? Do the Holley mounts move the engine back into the crossmember more? Are there any lower compressor mounts that help with the frame notch? I will be adding vintage air and they sell a bracket but didnt know if that was the one I need.
I will be using a TR6060 transmission and sounds like I need to make my own transmission crossmember.
Thanks in advance and I appreciate all the posts with good info here!
Bill
Old 11-29-2019, 11:46 AM
jimmythehand jimmythehand is offline
try lsx concepts, or concept one. can't remember which one i went with, but did LSA swap with speed tech subframe and did not have to notch frame.
The Following User Says Thank You to jimmythehand For This Useful Post:
billohio (11-30-2019)
Old 12-05-2019, 01:54 PM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
Bill, you will need to swap oil pan and remove oil cooler from LSA motor they hold 8 quarts of oil and wont fit the frame as sump is too long - if you didn't already know this
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
Old 01-09-2020, 09:14 AM
GEARBOXGARAGE's Avatar
GEARBOXGARAGE GEARBOXGARAGE is offline
Here's the A/C bracket that Speedtech suggested for running an LSA in their ExtReme subframes. The place is called Kwik Performance and they have a mini LSA A/C mount specific for LSA swaps into vintage vehicles or low clearance swaps.
http://www.kwikperf.com/lsx_high_mount.html
-MIKE
The Following User Says Thank You to GEARBOXGARAGE For This Useful Post:
camcojb (01-09-2020)
Old 01-10-2020, 07:00 AM
Thanks guys. I am getting about ready for a test fit and wondered what to do with the oil cooler too. Did anyone use something to replace the oil cooler??
Old 01-11-2020, 06:55 AM
joeko23 joeko23 is offline
There are oil coolers like this, but they don’t use coolant like the stock unit not sure if that makes any difference. All my research in the subject pointed to that most people just delete the oil cooler.
https://www.amazon.com/Aluminum-Engi...97757500&psc=1
