Old 11-29-2019, 01:53 PM
fastd fastd is offline
Default 1972 formula
Having my car done by a pro in florida.
He had done so many subtle and not so subtle things to things to the car...
Here is one that i really love...he made the air scoops functional to make “ram air” work again.
The Following User Says Thank You to fastd For This Useful Post:
cpd004 (12-07-2019)
Old 11-29-2019, 08:07 PM
NOT A TA's Avatar
NOT A TA NOT A TA is offline
That's a cool idea, I like it.
Who's doing it?
John Paige
lab-14.com
Old 11-30-2019, 10:45 AM
Who's doing it?
He's an independent guy based in Ocala, FL - Jeff Gaudin (954.245.5600)
He's done 5 cars for me over the last 10 or so years. While I don't think it's appropriate to turn this into an advertisement, he did solve problems that other Firebirds owners would have...
- he made brackets that straighten the fiberglass hoods to take the bow out of it; that bow created gaps on both sides of the hood line that bothered me every time i looked at it;
- he made fiberglass inner fenders that weight 3.5 lbs a piece (vs 21 lbs for stock); not for the weight savings; did it to create clearance for larger tires - mine are 295/30/19 fitted on the front;
- he made brackets for the lower shock mounting points with the rear leaf spring set up that created space to install lowering blocks that permitted lowering of more than 1-2"s while also permitting a slightly wider tire.
Old 12-01-2019, 06:42 AM
cpd004's Avatar
cpd004 cpd004 is offline
Is the MAF going to be eliminated?
1971 Firebird
2017 SS
Old 12-01-2019, 08:04 AM
Default Maf
No. I’m no expert on these conversions...why do you ask?
Old 12-01-2019, 12:34 PM
carbuff's Avatar
carbuff carbuff is offline
What are you going to do for intake air filtration? Is there some kind of filter in that hood area behind the plate?
As for the inner fenders, I run 315 / 30 / 18's on the front of my car with the stock inner fenders. I did slightly roll the fender lip, but otherwise no other reshaping of the inner fenders. The Firebird inner fender sheet metal and fender shape offer more room than the 2nd gen Camaros, so it's a bit easier to fit the larger tires.
Old 12-01-2019, 06:18 PM
Bryan, I believe it's a triangle filter inside the housing under the hood.
I do like this filter idea. Please show us pics of these inner fenders as well as the rest of the car. We love 2nd gens. Welcome to the site.
Old 12-01-2019, 08:42 PM
Thumbs up Filters
There are two filters,one for each snorkel inside the triangular case.
I’ve heard that different years w gen firebirds have different clearances. 315 on the fron with stock fenders is as big as I have heard though
Old 12-01-2019, 09:39 PM
Default Pictures
Working on getting some better pictures...
Old 12-02-2019, 10:26 AM
Default Filters
Under the case
