Old 01-29-2020, 06:05 AM
Stielow's Avatar
Stielow Stielow is offline
Matt is a true craftsman.
Stielow Engineering
The Following 4 Users Say Thank You to Stielow For This Useful Post:
Dannnn (01-30-2020), fleetus macmullitz (01-29-2020), Sonar Chief (01-29-2020), WILWAXU (01-29-2020)
  #162
Old 01-30-2020, 07:00 AM
Ketzer's Avatar
Ketzer Ketzer is offline
Heavy fab work. Adding a diff cooler. The Gen 5 ZL1 uses a oil to oil diff cooler. The transmission has a transmission oil pump in it. Pump the trans fluid to the radiator, through a oil to water oil cooler then to the diff thought a oil to oil cooler. The the fluid returns to the transmission. I’ll use a stand alone electric transport oil pump to circulate the fluid.
I repurposed the diff cooler to my GearFX housing. Made a steel box out of 3/16 mild steel (In hindsight 1/8 might be ok). Hogged out a big hole making sure the cooler clears the center section. Weld it all back together. The 3/16 plate did not warp when I welded it.
I did the same modification to Hellfire and Jackass. I did not add this to Gunner and I could over temp the diff in 4 20 min track sessions.
VERY cool!
Does this system get an external filter of some kind?
Does it add much oil capacity overall?
Old 02-01-2020, 06:14 AM
wiedemab's Avatar
wiedemab wiedemab is offline
Default Lead?
Mark,
I would assume they are the reall stuff, but do you know if they are using real lead or the new "lead-less" solder.
Just curious. Car is going to be so cool! - - as yours always are.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 02-03-2020, 01:29 PM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Love to follow your builds Mark ....... some much craftsmanship and great ideas!!
Old 02-05-2020, 11:07 AM
Sled Alley Sled Alley is offline
Originally Posted by wiedemab View Post
Mark,
Yes the lead is the real stuff its 80/20. The new lead-less solder just isnt the same it doesn't seem to have the bite like the old stuff does
http://www.sledalley.com
Old 02-06-2020, 03:07 AM
Maybe it's already been asked and I missed it . Why are you using lead vs any type of typical bondo ?
Old 02-06-2020, 06:35 AM
Steve68 Steve68 is offline
Yes resonators before the mufflers.
If you want to get what was on Gunner Hooker sells it.
Nice Kit, is this all premade for a mini tubbed gas tank??
Old 02-06-2020, 07:11 AM
cjfirstgen's Avatar
cjfirstgen cjfirstgen is offline
Correct. Worked well for my build although I did add more v-bands. They utilize a few band clamps which falls short of expectations IMO.
Project "Mercury Rising" '69 Camaro : https://lateral-g.net/forums/showthread.php4?t=41460
The Following User Says Thank You to cjfirstgen For This Useful Post:
Steve68 (02-06-2020)
  #169
Old 02-06-2020, 01:55 PM
Stielow's Avatar
The engine bay is going back together today. I like this part of the project.
Packaging all the stuff in!
Stielow Engineering
The Following 5 Users Say Thank You to Stielow For This Useful Post:
fleetus macmullitz (02-09-2020), jarhead (02-06-2020), Sonar Chief (02-06-2020), will69camaro (02-07-2020), WILWAXU (02-06-2020)
  #170
Old 02-07-2020, 06:28 AM
clill's Avatar
clill clill is offline
Yep...Looking like a Stielow science project......
The Following User Says Thank You to clill For This Useful Post:
