Old 02-21-2020, 04:58 AM
Sled Alley Sled Alley is offline
Originally Posted by jmac View Post
Ok, another question for you Mark!
With the DSE subframe, what transmission cross member are you using?
I know the DSE engine mounts move the engine back 1.5 inches, and they say to use a stock style cross member. What are you using in this build, and what have you used in past builds? The closest pic I could see was on post #61, but it's far in the background and I can't really make it out.
Thanks again for your time and expertise!
The LT motor mounts and trans cross member are both hooker blackheart. We built the first set off gunner and got all of the angles set and holley is now producing them. They fit great and everything bolts in as it should. You do have to raise the tunnel to get correct driveline angle
http://www.sledalley.com
The Following 2 Users Say Thank You to Sled Alley For This Useful Post:
dhutton (02-21-2020), jmac (02-21-2020)
  #192
Old 02-21-2020, 06:25 AM
jmac jmac is offline
Ahhhhhh, that's right, I forgot this was an LT series engine!
What have you guys done for LS engines in the past using the DSE subframe? I know DSE has their own engine mounts for the LS engine for their subframe, but kind of leave you hanging on the trans cross member.
And would you happen to have any pics of the interior trans tunnel mods you've performed?
Thanks!
Old 02-21-2020, 06:56 AM
JON Q's Avatar
JON Q JON Q is offline
Thanks!
If you go back to the build of Jackass 2.0, you will find the pictures there on the cross member Mark has built on Hellfire and JA for the LS9. It is on page 68. If you look at some of the DSE builds you will also find they have built a similar setup
The Following User Says Thank You to JON Q For This Useful Post:
jmac (02-21-2020)
  #194
Old 03-06-2020, 06:39 AM
Stielow's Avatar
Stielow Stielow is offline
Some random build photos.
Stielow Engineering
Old 03-06-2020, 06:47 AM
Stielow's Avatar
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
fleet (03-06-2020), pannetron (01-03-2021)
  #196
Old 03-06-2020, 06:57 AM
jarhead's Avatar
jarhead jarhead is offline
Amazing detail!
joe
Semper Fi
My 68 Torino
Old 03-06-2020, 07:35 AM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
I think Mark ought to build these for the rest of us - how about it Mark,are you up to do 2-3 millions of these for your followers?
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
Old 03-06-2020, 07:55 AM
Stielow's Avatar
Default Camaro LT5
Modo Innovations Gas Pedal adaptor
Stielow Engineering
The Following 3 Users Say Thank You to Stielow For This Useful Post:
camcojb (03-06-2020), jmac (03-22-2020), Musclerodz (03-07-2020)
  #199
Old 03-06-2020, 09:09 AM
Stielow's Avatar
We are dry building the whole car this time before paint. Matt is putting the front clip on it now to finish the engine bay.
Just finished the dip stick for dry sump tank.
Reassembling the front end
Stielow Engineering
Old 03-06-2020, 11:22 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Amazing work!! You have a color picked out yet Mark?
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Newby (03-08-2020)
