Old 03-17-2020, 01:15 PM
Stielow's Avatar
Stielow Stielow is offline
Moving on to the induction tube. Because GM went to a bigger 95 mm throttle body on the LT5 we are going to a 4.5 inch induction tube.
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
pannetron (01-03-2021), WILWAXU (03-19-2020)
  #242
Old 03-17-2020, 05:21 PM
colorado80439 colorado80439 is offline
Originally Posted by colorado80439 View Post
Incredible work, what's better than a Stielow build on Lateral G.
I've asked this question on the LSX conversion topic and researched most builds with dry sump that I could find, but I'm looking for the best option of running -12 oil lines from an oil tank mounted in the passenger fender (in front of the door) to the pan of an LS7 with DSE subframe and headers, I would think I need positive gravity feed from the tank to the pan. Any input is greatly appreciated
Thanks Dave
Anybody?
Old 03-18-2020, 05:15 AM
Stielow's Avatar
Anybody?
I have mounted the dry sump tank in the passenger fender in front of the tire. (Where the battery used to be). The feed line ends up about 4 long and has to route over the DSE crossmember.
I did not have an issue doing it that way on Red Devil, Jackass 1.0, Camaro X and Mayhem.
My new set up putting it in the cowl significantly shortens the feed line. I have also upper the feed line to a -16 AN because I did not see a downside and it errors proofs the. Installation.
So to answer you question it does not need to gravity feed. But the guys who designed the system told me not to make the feed line more than 5 feet long if you stay with -12 AN.
People who think they can put an LS7 dry sump tank in the trunk you can not. I asked a few years ago. The oil pump was not designed to do that and it will oil starve.
Mark
Stielow Engineering
The Following 10 Users Say Thank You to Stielow For This Useful Post:
89 RS (03-18-2020), colorado80439 (03-18-2020), fleetus macmullitz (03-18-2020), Goosesdad (03-19-2020), jmac (03-18-2020), Ketzer (03-18-2020), thedugan (03-18-2020), warhawkchevelle (03-22-2020), will69camaro (03-18-2020), WILWAXU (03-19-2020)
  #244
Old 03-19-2020, 06:50 PM
jmac jmac is offline
Beautiful. Do you have any pics of where the air filter element is tucked in to the fender well? Just curious to see what you did there. Is there a closeout panel and the filter is blocked off from the engine compartment, or is the filter element just sitting right on the end of the pipe?
Thanks!
My 1967 Camaro
Old 03-20-2020, 03:15 PM
Stielow's Avatar
Thanks!
Stielow Engineering
The Following 3 Users Say Thank You to Stielow For This Useful Post:
jmac (03-20-2020), syborg tt (04-04-2020), will69camaro (03-20-2020)
  #246
Old 03-20-2020, 06:50 PM
JD67SS's Avatar
JD67SS JD67SS is offline
Just curious... are you directing Matt and crew at every turn, or do they know what to do? It’s hard to tell based on the pics, and while I would guess you’re steering the ship, I just wondered how much direction you have to give them.
JD
Old 03-20-2020, 11:07 PM
marine15Z28 marine15Z28 is offline
Is that tube aluminum or steel
Old 03-21-2020, 01:57 PM
Stielow's Avatar
Aluminum
Stielow Engineering
Stielow's Avatar
Default Camaro LT5
Aaron Oberle made me some fender emblems. Because I want them to fit the fender the are not flat. Curved in both directions. Not a simple part!
Stielow Engineering
The Following 7 Users Say Thank You to Stielow For This Useful Post:
fleetus macmullitz (03-21-2020), jarhead (03-27-2020), JohnC (03-23-2020), Roscoe03 (03-22-2020), SSLance (03-22-2020), waynieZ (12-01-2020), will69camaro (03-21-2020)
  #250
Old 03-21-2020, 02:10 PM
Stielow's Avatar
JD
Matt is more than capable and does build cars without my daily interaction. On my stuff I know how I want it. We work and communicate very well. Sometimes we do it my way and often he has a better idea and we do it his way. In all the projects we have done together I can only think of a couple items that had to be scrapped because it did not work out. Early on Matt like to make things “street roddy”. I like think functional and OE looking. He nails that. Look at my Blazer and Lillard’s S15. Looks like a prototype GM build. Killer work and attention to detail.
Matt thinks thought the whole build. He and his guys are very talented. Usually project creep comes from me.
So to answer your question, yes I communicate with Matt daily because I’m a control freak. Does he need me to nope.
Stielow Engineering
camcojb (03-25-2020), fleetus macmullitz (03-21-2020)
