Old 08-31-2020, 01:00 PM
69Toronto 69Toronto is offline
My buddy just put one on his 69 Nova, which is the same kit as the 67-69 Camaro. It's a big block car which can have fitment issues on it's own if the frame stands and mounts aren't correct. But in his case he could not get it to clear the headers (tried Hooker and custom Lemons headers). The shop called Ridetech and they told them headers wouldn't work with that system.
I know the install pics show headers but I believe it's an LS swap car. I would call and verify from Ridetech first if that will be an issue with what you're doing. Other than that the shop doing the work had installed these before on other cars (not first gens) and liked the system and had no fit issues.
i should have mentioned I have a set of Doug's headers on a sbc they are not traditional long tubes more like 4 to 2 to collector type of thing...would almost call them midlength?
Old 08-31-2020, 07:57 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Originally Posted by 69Toronto View Post
Hoping someone can chime in on TruTurn in 2020
I have a stock subframe, global west upper and lowers
stock spindle, AGR ps box, QA1 coilovers, 18x8.5 rushforths and 245 40 18s on it
i bought the car with all adjustments maxed out to make the car as low as possible....it rides like crap, rubs when i crank the wheel in both directions.
control arms basically on the bump stops
switching things around now...my goal is to just get the car as low as possible where everything is performing correctly and be able to make a proper 3 point turn or a U turn like a normal person lol
i like to lowered stance but realize the car will have to go up
Im hoping to add some global west shorter subframe bushings
replace the 350lbs springs with something stiffer
I am thinking of adding drop spindles, but then read about the TRUTURN
Im not looking to run a 275 tire...I just want to get the lowered stance and be able to turn on a 245 tire
is truturn what i need here or can I just but some drop spindles and call it a day?
thank you...Bob
The Tru Turn was designed to be able to get the steering arm higher on the spindle so that you can run more backspace as the wheel will fit over the steering arm instead of hitting it. That does no sound like something you need.
The two main obstacles you encounter when lowering a car are suspension travel and steering angle/wheel size before something hits. The suspension travel can be fixed with a drop spindle. The steering angle and wheel size both come down to how much physical space you have before the wheel hits the fender or inner fender, and the only way to fix that is to get smaller wheels, or clearance the sheetmetal to allow for more room!
Hope that's at least a little bit helpful!
http://bestofshowcoachworks.com
(760)480.0227
1969 Camaro - always broken GM Design winner
1965 Mustang - widebody fastback
2006 Coyote swapped "Rental Car"
Up next:
Steve's GT40
The Following User Says Thank You to Matt@BOS For This Useful Post:
camcojb (08-31-2020)
  #253
Old 09-01-2020, 05:52 AM
decided to try cutting the top hats off and make the car a true coil over car while at the same time extending shock travel
also going to add lower subframe bushings
also need to rebuild a QA1 already....1800 miles...hopefully that tucks the top of the tire and allows my to make a 3 point instead of a 76 point turn
Old 09-01-2020, 07:34 AM
dhutton dhutton is online now
You may put your steering column rag joint into bind with lower subframe bushings.
I’m not seeing how either of those changes will gain you improved turning radius.
Old 09-01-2020, 03:32 PM
BigBronco's Avatar
BigBronco BigBronco is offline
Originally Posted by cwylie View Post
BigBronco - You went to UT and had a 4th gen F-body right? I think you and I went to the track once like 15 years ago and used to play Halo on Xbox if I remember correctly.
A blast from the past but yep. Use to be on TRS and what not. Did not have a 4th gen though but was with all of the 4th gen crowd/ls1tech, etc.
Long time man!
2022 F-350 Tremor | Daily Driver
1972 Nova | LSX | 6 Speed | Speedtech Suspension | C6 z06 Brakes | Forgelines
1968 Firebird | LM7 Swap | 4L60e | Ridetech Suspension | C6 Brakes
2012 Corvette ZR1 | Bolt-Ons | Forgelines
2001 Trans-Am WS6 | Cam | Six Speed | Slow
1969 Mach 1 Fastback | New Project
Old 09-02-2020, 07:19 AM
ive been told about loosening the rag joint.....AGR steering box needs to come out.
Turning ability should increase when I raise the car an inch or so....(I hope) fender lips also getting massaged. The coilover mod Im doing is to better the ride quality
any suggestions on what else I should be doing?
Old 09-02-2020, 09:10 AM
I think you will lose some of the gain when you install the half height bushings.
Anvil wide inner fenders would help quite a bit. Or have your stock inners modified.
Are you hitting the sway bar? A splined bar may gain some clearance.
Post up a pic of your ride height.
Old 09-04-2020, 04:28 AM
The car only rubs on the outside fender lip
I measured the ride height
22 3/4" front 23 3/4" rear......
yes I know how ridiculous that height is....lol
Old 09-04-2020, 06:28 AM
Increasing negative camber can help a little. What are your alignment settings?
Old 03-09-2021, 03:27 PM
glr0212 glr0212 is offline
Just checking in on this 6 year old thread. I wonder if ridetech's president still hates me....
