Old 09-13-2020, 06:47 AM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by RDuke View Post
Can you remind us, are you using something like Gates PowerGrip heatshrink for your hose claps?
For the stuff that needs service it is the Gate Power Grip clamps. For hoses that need to be serviced an regular worm gear hose clamp with heat shrink tubing over the strap to make it black. Keeps things clean looking.
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
svtredsnake (09-17-2020), WILWAXU (09-13-2020)
  #512
Old 09-13-2020, 06:58 AM
fleet's Avatar
fleet fleet is online now
Mark,
I really like the clean look of the rear of the car.
Could you explain your rear spoiler choice (instead of say an adjustable rear wing) and how it works on track?
Thanks.
Old 09-13-2020, 09:21 AM
Stielow's Avatar
Mark,
Thanks.
Like you said it looks clean. If I was building this to be a track weapon I would do a different rear spoiler. 99% of time I’ll just be driving this on the street. For the few open track day I do it will be fine. I would rather have it look stockish vs some “Ricer” wing on it.
Stielow Engineering
The Following 6 Users Say Thank You to Stielow For This Useful Post:
Che70velle (09-13-2020), dhutton (09-13-2020), fleet (09-13-2020), kwhizz (09-13-2020), ScotI (09-13-2020), Sieg (09-13-2020)
  #514
Old 09-13-2020, 03:39 PM
Curious as to why you haven't or when you're going to put a I.R.S on one of your Camaros Mark ?
Old 09-13-2020, 08:07 PM
patriot68 patriot68 is offline
Can you post the upper radiator hose part # please?
1968 Camaro, LS1/T56,martz chassis,19x10/18x8 Budniks,245/45/18,295/35/19 {Sold}
http://www.fquick.com/patriot68
1971 Firebird - Speedtech Extreme Subframe/Torque Arm, LS3/4L80E, 19x12/18x10 Budniks
Old 09-14-2020, 06:04 AM
Stielow's Avatar
Dayco Hoses
E71703
D71636
Stielow Engineering
dhutton (09-14-2020), patriot68 (09-14-2020)
  #517
Old 09-14-2020, 06:07 AM
Stielow's Avatar
Default Camaro LT5
I’ve worked on a lot of IRS setups at GM and they are hard to get correct. I’m happy with my solid axles. Power hop issues. Breaking halfshafts and CV joints. Once you get to 800 plus Ft*Lbs a IRS get very big and heavy.
Stielow Engineering
fleet (09-14-2020)
  #518
Old 09-14-2020, 07:32 AM
RDuke RDuke is offline
Thanks!
Old 09-14-2020, 11:54 AM
fleet's Avatar
Mark,
Leaving cost out of the equation for now, would you ever want to install a full frame chassis in a 1st gen?
What would be your reasons pro or con?
Thanks...
Old 09-14-2020, 01:28 PM
cpd004's Avatar
cpd004 cpd004 is offline
If I missed it in here, my apologies. How do you normally handle your connections at the battery as far as any circuit protection and then where they (or it/positive) runs in to the engine bay for distribution?
BTW...thanks for always giving us a look behind the curtain and most importantly, the why you do things a specific way.
1971 Firebird
2017 SS
