Old 09-29-2020, 03:21 AM
Stielow's Avatar
Stielow Stielow is offline
Default Camaro LT5
You may recall earlier we added a oil to oil diff cooler. This is the Gen 5 ZL1 diff cooler.
These are the cooling lines that move the transmission fluid. It is a loop. There is a electric pump that circulates the trans fluid through a oil to water heat exchanger in the radiator then the chilled trans fluid gets pumped back to the diff. It goes though a oil to oil heat exchanger then back to the trans. This is how GM does it in production except the trans pump is built into the transmission.
The line pass thought the DSE rear crossmember then go through the passenger rocker. Keeps the packaging clean and the line protected.
Stielow Engineering
The Following 9 Users Say Thank You to Stielow For This Useful Post:
cpd004 (09-29-2020), dhutton (09-29-2020), fleet (09-29-2020), Ketzer (09-29-2020), kwhizz (09-29-2020), streetbird (09-30-2020), syborg tt (10-05-2020), will69camaro (09-29-2020), WILWAXU (09-29-2020)
  #542
Old 09-29-2020, 06:11 AM
BigBronco's Avatar
BigBronco BigBronco is offline
Love that oil cooler setup. Quite a bit of fab but turned out phenomenal.
2022 F-350 Tremor | Daily Driver
1972 Nova | LSX | 6 Speed | Speedtech Suspension | C6 z06 Brakes | Forgelines
1968 Firebird | LM7 Swap | 4L60e | Ridetech Suspension | C6 Brakes
2012 Corvette ZR1 | Bolt-Ons | Forgelines
2001 Trans-Am WS6 | Cam | Six Speed | Slow
1969 Mach 1 Fastback | New Project
Old 09-29-2020, 02:25 PM
next Mark is going to tell us the pump only comes on when required by temp lol
Old 09-29-2020, 03:30 PM
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
The Following User Says Thank You to will69camaro For This Useful Post:
  #545
Old 09-30-2020, 09:03 AM
Stielow's Avatar
Random AN hoses
Stielow Engineering
The Following 7 Users Say Thank You to Stielow For This Useful Post:
ArisESQ (09-30-2020), cpd004 (10-02-2020), EVIL SS (09-30-2020), NAPA 68 (10-01-2020), syborg tt (10-05-2020), will69camaro (10-02-2020), WILWAXU (10-01-2020)
  #546
Old 10-01-2020, 07:20 PM
What hose are you using, Mark. I see it's Earls. I'm not familiar with a grey hose from them, though.
The car is coming together great and looking phenomenal as always.
Old 10-01-2020, 08:05 PM
I love the look of that hose, can't afford the crimper...
https://www.holley.com/brands/earls/...evlar_braided/
Old 10-02-2020, 06:12 AM
cjfirstgen's Avatar
cjfirstgen cjfirstgen is offline
Several brands carry the same hose under different names btw. Fragola Race-Rite Pro is what I went with on the my builds. The crimper and required dies, tooling, etc are certainly an investment but the time that it saves assembling hoses pays off in the long run. The performance, durability, flexibility (bend radius), flow and light weight of the hose made it worth it to me. The Pro or Extreme add an externally wound stainless steel wire that provides vacuum support and tighter bend capability.
Fragola Race Rite & Race Rite Pro
Brown & Miller Pro Gold Aramid Braid
Earl's Ultra Flex Kevlar Braided
XRP ProPlus Race Hose & ProPlus Extreme
Project "Mercury Rising" '69 Camaro : https://lateral-g.net/forums/showthread.php4?t=41460
The Following 2 Users Say Thank You to cjfirstgen For This Useful Post:
fleet (10-02-2020), syborg tt (10-05-2020)
  #549
Old 10-02-2020, 06:27 AM
69hugger's Avatar
69hugger 69hugger is offline
The hose is $24.00 a foot and you're worried about the crimper? (Although I didn't look at the price of the crimper...)
Bill
'69 Camaro / 534 BBC / DSE Built
'67 C10 / LS-3 w/Magnuson / Roadster Shop Chassis (SOLD)
'71 Blazer / LT4 / 8L90 / Roadster Shop Chassis / Ride Tech Air Susp.
Old 10-02-2020, 06:43 AM
Crimper is $3grand
Texas A&M BSME 2008
1992 Corvette ZR-1
