Old 10-23-2020, 07:15 AM
fleet's Avatar
fleet fleet is offline
Good progress Marty.
You are definitely putting your own unique McFly touch on it!
The Following User Says Thank You to fleet For This Useful Post:
syborg tt (10-23-2020)
  #1472
Old 10-29-2020, 07:57 PM
syborg tt's Avatar
Default Afco Fan Shroud Redo (( 08-02-20 ))
So being honest this part has not been fun.
Time to remove all of the paint and create a new way to mount the fan shroud.
Close enough to take it over to get painted.
Remember this edge from the first picture.
marty-mj
fleet (10-30-2020)
  #1473
Old 11-02-2020, 12:54 PM
64G-lark's Avatar
64G-lark 64G-lark is offline
Marty,
Your level of detail surpasses mine and the Camaro is really nice. It took me the last few evenings to get through all the pages. Very informative and I took a few notes ! I need to learn to use more blue tape. Is there a preferred brand and best place to purchase?
The Following User Says Thank You to 64G-lark For This Useful Post:
syborg tt (11-02-2020)
  #1474
Old 11-02-2020, 04:23 PM
syborg tt's Avatar
Originally Posted by 64G-lark View Post
Marty,
Thank you for the kind words.
I like the 3M tape the best and even though I pass two Home Depot’s on my way home from work I still go to Ace Hardware hoping to get a chunky bar.
marty-mj
64G-lark (11-02-2020), waynieZ (11-03-2020)
  #1475
Old 11-09-2020, 02:30 PM
syborg tt's Avatar
Default New Upper Mounts for the Radiator (( 08-17-20 ))
Time to make a better mouse trap.
I decided to go in a new direction with how the radiator was secured in place. Keeping with the "KISS Principle - Keep It Stupid Simple" I decide to make a flat bracket they will attach directly to the Core support with rubber Well Nuts.
And I might as well have Dennis "High Speed Welding" create a different way to mount the fan shroud.
and might as well fix the inlets/outlets so they match the waterpump.
Only one day later it's ready for me to pick up.
marty-mj
The Following 3 Users Say Thank You to syborg tt For This Useful Post:
fleet (11-10-2020), Goosesdad (12-12-2020), WILWAXU (11-10-2020)
  #1476
Old 11-09-2020, 02:46 PM
andrewb70's Avatar
Making progress!
Andrew
Instagram @dr__efi
I deliver what EFI promises.
My YouTube Channel
Old 12-11-2020, 04:46 PM
syborg tt's Avatar
Default Test Fitting the Radiator (( 08-26-20 ))
Now that the Afco "Direct Fit" Radiator is home and modified so it will work I might as well test fit it.
Cutting up some cheap radiator hose to make make sure I order the correct size hoses.
Next up...drill holes in the Core Support.
Eventually I will drill the holes larger and install "Well Nuts"
Works perfect
Testing a 3" Hose that I borrowed from a friend
Perfect Gap.
marty-mj
Goosesdad (12-12-2020), WILWAXU (12-11-2020)
  #1478
Old 12-11-2020, 04:55 PM
Looking good, Marty. Are you going to use pipe and couplings for the coolant hoses? Those glass coolant pipes are cool!
syborg tt (02-12-2025)
  #1479
Old 12-11-2020, 05:05 PM
syborg tt's Avatar
Default Billet Optima Front Mount Battery Tray. (( 09-07-20 ))
Since I plan to drive this car and really don't want the hassle of having a battery in the trunk. Ron from Wilson Muscle Cars and I designed a factory fit Billet Tray for the battery. Actually it was my idea and Ron drew it up and I had TJ make a few of these.
Since I am running the Anvil Carbon/Fiberglass Inner fenders. I can't use the inner fender to support the battery tray in the front. My solution is to drill a hole in my inner fender and run a support rod up from the Core Support bracket.
Good News...I found something to replace the Chunky Bars.
marty-mj
Old 12-11-2020, 05:18 PM
syborg tt's Avatar
Default Wiring, Wiring & more Wiring ((09-07-20 ))
Just cleaning up things a little bit.
Adding 40amp fuse which will also act as my kill switch.
The best $10.00 I have ever spent.
Final destination is the distribution block.
marty-mj
waynieZ (12-12-2020), WILWAXU (12-11-2020)
