12-26-2020, 08:15 AM
also looking at some of the BC forged and ESR 3 piece wheels....
tough decision....
The Following User Says Thank You to 69Toronto For This Useful Post:
12-26-2020, 04:30 PM
tough decision....
So many nice wheels, it's a tough decision. I'm relying on my wheel guy for advice as to best bang for the buck, and he said the BC Forged are, and he's a dealer for several of the top mfg's
12-27-2020, 07:54 AM
Wheels are certainly a tough choice. Your third choice looks great. Project is coming along nicely.
The Following User Says Thank You to cjfirstgen For This Useful Post:
12-27-2020, 09:45 AM
agreed BC forged for the money...for me its looking "too modern" or out of place on a 69 and Lip vs no lip
looking at litespeed wheels also https://www.litespeedracing.com/
12-29-2020, 10:12 PM
Mah Tars showed up today
The Following 5 Users Say Thank You to Rodknock For This Useful Post:
12-31-2020, 09:49 PM
Mounted the doors
Test fit #2. Re-mounted the doors back on the car. I'm going to pin the hinges this time around. Also need to fit the new Cowl hood, and Anvil parts, since I obtained all of these after the car was torn apart.
Was lucky enough to get a couple of days off of work to get a few things done, although most of my time was spent catching up on neglected chores around the house. Was really hoping to get more done on the car. I mounted the fenders today before work, but didn't get a chance to take pics.
Yes, the glass and the hardware are sitting in the door, to simulate the weight to make it hang properly.
I did find a little rust in the driver door, but it was easily repaired. Just goes to show what can be hiding under a primered or painted car, when you buy it.
The Following User Says Thank You to Rodknock For This Useful Post:
01-02-2021, 04:14 PM
Re-hung the fenders
Got the fenders loosely installed. Funny how I bagged and tagged every nut, bolt, and shim, but it still ends up needing to be tweaked. They just never go back together the same way twice.
I'm going to have to work the door gaps of the AMD fender on the passenger side, at the top along the curve, leading up towards the windshield. The angle of the curve in the panel is pretty far off from the curve of the door at the top. Also the door to fender gap at the very bottom of the door will need work. Not much though. It's more of an issue with the door, not the fender with that part. gaps are perfect at the rear of the door, and along the rocker panel, so doors are adjusted perfect.
Driver side has an OEM fender, so the gaps are fairly decent with that one. I just need to do some body work, and weld in the tab for the RS headlight stuff, since it was a standard fender.
01-09-2021, 11:20 PM
Door Gaps
01-09-2021, 11:38 PM
Passenger top fender
The Following 3 Users Say Thank You to Rodknock For This Useful Post:
01-09-2021, 11:44 PM
Finished gaps
The Following 6 Users Say Thank You to Rodknock For This Useful Post:
