Old 02-15-2021, 06:59 AM
BMR Sales's Avatar
I think the Statute of Limits still applies so I will take the 5th!
The Following 2 Users Say Thank You to BMR Sales For This Useful Post:
camcojb (02-15-2021), Spiffav8 (02-15-2021)
Old 02-15-2021, 03:26 PM
68454RS's Avatar
68454RS 68454RS is offline
I'll just let the picture speak for it's self.. and yes, I did mount a radiator and fire it up in the shopping cart. I'm the skinny blonde kid on the right
FB_IMG_1538614029036 by F G, on Flickr
The Following 6 Users Say Thank You to 68454RS For This Useful Post:
572Camaro (02-16-2021), BMR Sales (02-16-2021), BonzoHansen (02-23-2021), camcojb (02-15-2021), dhutton (02-16-2021), Spiffav8 (02-15-2021)
  #13
Old 02-15-2021, 04:19 PM
Default Trusted a body man
It must be the fumes..
The Following 2 Users Say Thank You to XLexusTech For This Useful Post:
  #14
Old 02-15-2021, 05:02 PM
chicken $#it lol
Old 02-15-2021, 07:48 PM
Che70velle's Avatar
I’m loving this thread guys. I’m embarrassed to say I have nothing to add, however I can’t help but think if only Mr. Weld were here for this one...oh the stories he could tell.
Thanks Dad!!
Old 02-16-2021, 07:18 AM
Steve68 Steve68 is offline
Thats a lot of weight for a sopping cart, close to 700lbs there 685 dry weight, scary!!!
Old 02-16-2021, 10:06 AM
ADY's Avatar
ADY ADY is offline
At 17, I pegged my parent's car at 135 mph on a freeway in the Bay Area. When I hit a bump and was nearly airborne, I s%&t bricks and ended my quest for top speed.
-Adam
1968 Camaro SS
Old 02-16-2021, 10:14 AM
anguilla1980's Avatar
anguilla1980 anguilla1980 is offline
You don't have to lie to hang hahaha
https://www.TheFoat.com/92GTA
1969 Pontiac Firebird w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black with black interior.
1992 Pontiac Trans Am GTA w/SLP Performance Package. Dark Jade Grey Metallic, grey leather, T-Tops.
Old 02-16-2021, 10:15 AM
Goosesdad's Avatar
Great stories here!!
19 yold. 84 Trans Am. Had an oil leak, thought I would Gunk the bottom so it would be a less messy repair (oil pan gasket). Put it in the grassy field behind my house, jacked it up and put it on stands. Fortunately, I did the shake test before climbing underneath. Yep, stands rolled in the grass and it fell to the ground. That would have been bad. Stupid stupid stupid
When I was very young, grew up next door to a short track racing family, still great friends today. The dad was working underneath a 57 Chevy race car and it slipped off the stands, frame crushed his jaw and his arms were trapped underneath the still mostly hot headers. Had to talk his wife through jacking the car up.
Still gives me chills.
Have a great day!
John
My Build Thread:
Old 02-16-2021, 10:56 AM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
I'm about 8 days into my first job as a mechanic at a Toyota dealer. I get this Jeep Comanche pickup truck thing that needed some power steering work done, a hose or pump or something. Well, I go to bleed the system and reach in to start it, and it's a manual transmission, and it starts. It stopped when it hit the workbench. Thought for sure I'd get fired, but nope.
Same place, a guy who worked across the shop from me suspected a bad fuel pump on one of those Toyota pickup motorhome conversion abominations. It's fuel injected. He decides the best way to test the pump is to remove it from the fuel tank (which you have to drop out to do btw) and then proceeds to place it in a metal drain pan full of gasoline. He grabs his handy 12 volt battery, some jumper wires, and places the pump in the pan of gas and connects her up. Well, it sparked and the ensuing flames spooked him causing him to knock the pan of gas off of the milk crate it was resting on. This is about the time, as I'm working across the shop from him, that I notice a co-worker walk by and grab the fire extinguisher off the wall behind me. I figure this is worth peeking out from around the open hood, and it was. Once everything settled down I walked over there. There was fire extinguisher stuff EVERYWHERE, but the funniest was all his sockets in the top of his tool box were filled with the stuff!
Then there was the FJ60 Land Cruiser I put about 3 rear main seals in because they wouldn't stop leaking. Come to find out I nicked the crankshaft on the first one, so I ended up putting a crankshaft in that beast of a thing. I only got paid for the first seal too!
Erik
69 Camaro
The Following User Says Thank You to ErikLS2 For This Useful Post:
camcojb (02-16-2021)
