Old 02-05-2021, 09:11 AM
68454RS's Avatar
68454RS 68454RS is offline
Default E-Stopp Electric e-brake info wanted
For those using the E-Stopp units, can you provide some insight as to the pros & cons? installation tips & tricks would be great. I'm thinking of using one on my 68 Camaro with 5th Gen Camaro e-brake backing plates.
Old 02-24-2021, 05:31 PM
Dchv66 Dchv66 is offline
Default E-Stopp E brake system
I will be installing E-Stopp on my 66 Chevelle within a few months. Car is currently undergoing major mods. My fab guy says he used them with great results so I decided to go that route with a Roadster Shop chassis.
Old 02-24-2021, 05:48 PM
cjfirstgen's Avatar
cjfirstgen cjfirstgen is offline
No real drawback except space availability on where to mount it. There are various solutions that have been completed. Here is mine:
Project "Mercury Rising" '69 Camaro : https://lateral-g.net/forums/showthread.php4?t=41460
The Following 2 Users Say Thank You to cjfirstgen For This Useful Post:
camcojb (02-25-2021), Spiffav8 (03-01-2021)
Old 02-25-2021, 08:00 AM
68454RS's Avatar
CJ, I went through all 41 pages of your build, I must have missed it but, I need more info on those subframe brackets. How you did the bolt through and such.
Old 02-25-2021, 08:26 AM
cjfirstgen's Avatar
I thought the larger bracket (2 to 1)came with the kit. The smaller bracket we made. The Estopp unit we used rivnuts and spot welded on the inside when we had the seat pan removed for the subframe connectors as I recall. Hope that answers your questions.
Old 02-25-2021, 01:47 PM
CJD Automotive's Avatar
CJD Automotive CJD Automotive is offline
The con I see, and why I am using a mechanical lever, is that is just a parking brake, not an emergency brake. There is no way to modulate the braking to the axle, it's either on or off, so locked up or free wheeling. If you were in a situation and lost brakes on your car (especially track), you can at least modulate a lever by keeping the release pushed with your thumb (we all did this right after learning to drive!).
Craig Scholl
CJD Automotive, LLC
www.CJDAUTOMOTIVE.com
"I own a Mopar, so I already know it won't be in stock, won't ship tomorrow, and won't actually fit without modification."
Old 02-27-2021, 10:14 AM
ProTouring442's Avatar
Try slowing your car from 70mph with your parking brake. Back in the days of full sized rear drums, you could do some slowing. Today, with tiny parking brake calipers or the little 6" drums, forget about it.
You ever wonder what medieval cook looked at the guts of a pig and thought, "I bet if you washed out that poop tube, you could stuff it with meat and eat it."
Old 02-27-2021, 12:01 PM
Sheck44's Avatar
Sheck44 Sheck44 is offline
Default E-Stopp
Like CJ, cannot agree more ...
Ive used 3 of these kits on my cars and all worked brilliantly
4th one in my garage to use on the 73' FJ55
'Build it RIGHT the 2nd time'
69' SS X11 PRO-TOURING - SOLD
73' FJ40 LS - SOLD
1966 FJ40 R2.8 -SOLD
911 Hotrod - SOLD
2002 Gated 360
Next up - "Killer Piggy"
67' Camaro - Take-Over'
The Following User Says Thank You to Sheck44 For This Useful Post:
68454RS (02-27-2021)
Old 03-01-2021, 04:51 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Crew at CHC mounted mine in the trunk. I’ll upload the pic and post it when I get home.
Curtis
The Following 2 Users Say Thank You to Spiffav8 For This Useful Post:
130fe (03-01-2021), 68454RS (03-01-2021)
Old 03-11-2021, 06:36 PM
65 Drop Top 65 Drop Top is offline
The estopp is factory wired to only operate when the ignition is turned off. So unless that is bypassed, and you lose your brakes at speed, you’d have to kill the ignition to get the estopp to activate. You’d then lose power steering and transmission control. Seems like a lot to manage in an emergency situation.
My plan in an emergency is to stomp on my lokar e brake pedal and start downshifting like a mofo.
And I have had a master cylinder go bad, actually I believe mine was the one that triggered Wilwood’s recall a few years back.
