Old 03-08-2021, 06:11 PM
vet57air's Avatar
vet57air vet57air is offline
Working on details and the last of the wiring. Hopefully start it soon.
The Following 8 Users Say Thank You to vet57air For This Useful Post:
camcojb (03-08-2021), dhutton (03-09-2021), Goosesdad (03-15-2021), jarhead (04-07-2021), Ketzer (03-09-2021), syborg tt (03-08-2021), waynieZ (03-09-2021), WILWAXU (03-09-2021)
  #42
Old 03-09-2021, 01:49 PM
Originally Posted by vet57air View Post
Thank you. I have a lot of fun with the Tourliner. It was much work and is something that I could not do again. Here are some links:
https://www.facebook.com/watch/live/...atch_permalink
https://www.flickr.com/photos/909015...l5F1YA_KmKWKXk
https://www.youtube.com/watch?v=HRAwC3HKAZM&t=18s
I just got to watch the videos of the Tourliner, now I'm even more impressed with your talent. Amazing work and vision.
The Following User Says Thank You to waynieZ For This Useful Post:
vet57air (03-09-2021)
  #43
Old 03-09-2021, 05:49 PM
clill's Avatar
clill clill is offline
What a nice truck !!!!!!!
The Following User Says Thank You to clill For This Useful Post:
  #44
Old 03-11-2021, 04:40 PM
vet57air's Avatar
Tried to start my crate LT4.... not a sputter. Fuel pump ramps up and I have fuel at the engine. ECU gives me a PO 00006 code, from which is suppose to be for a fuel shut off valve. Can see nor smell fuel on plugs. On the back of the engine I know of two plugs one on each side for the injectors and one other on the drivers side that looks like its for the intake (maybe pressure)? Anyone know where this valve is located? Is there a plug for it?
Old 03-11-2021, 05:25 PM
vet57air's Avatar
I see in the GM manual it makes mention of a "soak and idle" which is to connect the battery for 8 hours before starting. "Turning on the ignition for any length of time may cause you to have to soak an additional 8 hours". I didn't do the soak. Could that be the issue?
Old 03-12-2021, 09:48 AM
vet57air's Avatar
Got it running this morning. I had cleared the active code PO 00006 yesterday.
So I imagine it was that or it needed the "8 hour soak and idle".
The Following User Says Thank You to vet57air For This Useful Post:
camcojb (03-16-2021)
  #47
Old 03-14-2021, 08:19 PM
Congrats on getting it started!
What's the purpose of the soak and idle? I've never heard of this before.
Old 03-16-2021, 09:31 AM
vet57air's Avatar
I read it in the erod LT4 manual. It is not very clear, but seems that they want the battery hooked up to the ecu for at least 8 hours without turning the ignition on. From the little info I could find it sounds like it gives the ecu time to do diagnostics.
WSSix (03-19-2021)
  #49
Old 03-25-2021, 10:26 AM
This thing is stunning !!!!!!!
The Following User Says Thank You to Jimbo1367 For This Useful Post:
vet57air (03-25-2021)
  #50
Old 04-02-2021, 09:05 AM
vet57air's Avatar
My guy Marc Latrace from Miracle upholstery foamed up my stock seat.
syborg tt (07-02-2021)
