Old 01-22-2022, 08:12 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Default T56 Magnum help...
*also asked this question in the transmission section with no answers...figured it'd get more traction here
Guys, can someone give me a part number for a vehicle speed sensor for a Tremec T56 Magnum. I've looked up a part number and need to know if this will suffice.
See link >>>>> https://www.summitracing.com/parts/dfp-ss10569
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 01-22-2022, 08:38 AM
130fe 130fe is offline
Thumbs up
The Ford type sensor is 4400-640-019. Did your sensor go out?
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 01-22-2022, 08:58 AM
214Chevy's Avatar
No, my transmission is brand new. Finally, about to get my car running. I hadn't looked at it in a while. Does it come with it...? Also, if I do need one, the Ford part number is correct for my GM T56?
'68 C10 swb
'72 Chevelle
Old 01-22-2022, 10:17 AM
Bought my T56 Magnum new from American Powertrain, came with the sensor.
Old 01-22-2022, 10:58 AM
214Chevy's Avatar
Bought mine from Jeg's years ago and the guy wiring my car says it's not there. So, I have to get one from Summit.
'68 C10 swb
'72 Chevelle
Old 01-22-2022, 11:13 AM
The number on mine is 10456577. Seems to be a Ford part. This is on a GM T56 Magnum.
Old 01-22-2022, 02:09 PM
214Chevy's Avatar
Thanks Chris and Jody...
'68 C10 swb
'72 Chevelle
Old 01-25-2022, 12:43 PM
dontlifttoshift's Avatar
dontlifttoshift dontlifttoshift is online now
It's the Ford sensor that goes in there. Always has been, same with the TKO/X.
I have never seen one with out it.
Are you sure your wiring guy isn't looking at the drivers side of the trans where the mechanical pickup would be?
Donny
The Following User Says Thank You to dontlifttoshift For This Useful Post:
camcojb (01-25-2022)
Old 01-29-2022, 03:46 PM
214Chevy's Avatar
Donny, that's exactly what he did. I told him it was there and to jack the car up and look on the passenger side and sure enough, it was there. He was thinking I had the TR6060 where it was normally on the driver's side.
'68 C10 swb
'72 Chevelle
camcojb (01-29-2022)
Old 01-31-2022, 06:10 AM
Good deal. Make sure you get a plug for the drivers side, the rubber thing in there won't stay in there long.
Donny
camcojb (01-31-2022)
