Old 02-02-2022, 11:54 AM
syborg tt's Avatar
Default My ARP Hardware is Here !!!!! ( 01-5-22 )
I sincerely think ARP and Summit Racing are two of my favorite company's. I know I have spent a bunch with both of these company's over the years.
One would think with as much stainless steel hardware that I have installed that I would have remembered to put a little bit of anti-seize
on the bolt. Seriously all I was doing was just setting the nut on the bolt and I barely spun it on and it seize up.
Ugh !!!
If you followed this thread from the beginning you know this isn't the first time this has happened. So, I grabbed a larger
rachet and a much larger box end wrench and snapped the bolt.
I might as well install the arms since I have a couple hours before I call it a night.
and no more shims
I made sure to take a couple pictures of the shims that I used on the calipers.
I took the calipers off to reduce the weight of the spindle as I was trying to do this fast and easy.
Installed
Drivers side is on and it only took about 10 minutes.
For now I just stuck in two larger nuts as eventually I will be installing firewall strut braces.
When the arms were shipped the hardware kit didn't include washers which drives me nuts.
So I installed washers with the new hardware.
Once again these are the tools that came out to perform this job.
I am sure the box of Dots was from Halloween as they were a little hard but still good.
marty-mj
The Following 3 Users Say Thank You to syborg tt For This Useful Post:
fleetus macmullitz (02-02-2022), Mikael A (02-06-2022), waynieZ (02-02-2022)
  #1762
Old 02-06-2022, 12:54 PM
Mikael A Mikael A is offline
I love DOTS,looks great as always.
Mike a
The Following User Says Thank You to Mikael A For This Useful Post:
syborg tt (02-07-2022)
  #1763
Old 02-09-2022, 06:30 PM
syborg tt's Avatar
Default Holley EFI Tank Remes Autobody ''WOW'' (01-17-22 )
I dropped the Holley Tank off at Remes Autobody to get painted gloss black as I didn't like the idea of the tank being silver/gray in the back of
the car. When I went back to pick up the tank I was expecting a nice simple black paint job. Well this is far from simple. Once again they went
above and beyond and wow is all I can say. It is simple stunning and the crazy part is it matches the powder coating that the guys at Pro-Tek
Powder Coating applied almost perfectly.
marty-mj
fleetus macmullitz (02-09-2022), Roscoe03 (02-10-2022)
  #1764
Old 02-09-2022, 07:01 PM
syborg tt's Avatar
Default My OCD is getting the best of me. ( 01-17-22 )
I want to make the car as easy to work on as possible so, I am spending a little bit of time now that will hopefully save me time in the future.
If you go way back you will see that I ran all of the wires that go into the trunk through the drivers side rear quarter. This enabled me to pull
the wires out through "B" pillar vent. Which made it easy to wrap each wire loom individually and pass it over the wheel tub into the trunk.
Eventually I moved over to the wires in the trunk.
I used weather pack connectors on all connections.
Of course I labeled everything.
I had hoped to finish this project but unfortunately it was late and I needed to get up early in the morning so I called it a night.
side note.
Yep, I actually got stuck in the trunk when I was doing this and nope I couldn't reach my phone to call my wife to help me get unstuck.
Eventually, I just relaxed for a couple minutes (which felt like an eternity) and I was able to unwedge my elbow from the rear quarter.
marty-mj
The Following 4 Users Say Thank You to syborg tt For This Useful Post:
camcojb (02-10-2022), fleetus macmullitz (02-09-2022), Ricochet (02-10-2022), Roscoe03 (02-10-2022)
  #1765
Old 02-10-2022, 11:01 AM
camcojb camcojb is online now
side note.
syborg tt (02-11-2022)
  #1766
Old 02-10-2022, 11:31 AM
fleetus macmullitz's Avatar
Did you figure out why you got stuck MJ?
覧覧覧覧覧覧覧覧覧覧覧-
The Following User Says Thank You to fleetus macmullitz For This Useful Post:
  #1767
Old 02-11-2022, 08:53 AM
jarhead's Avatar
jarhead jarhead is offline
joe
Semper Fi
My 68 Torino
The Following User Says Thank You to jarhead For This Useful Post:
  #1768
Old 02-11-2022, 06:32 PM
syborg tt's Avatar
覧覧覧覧覧覧覧覧覧覧覧-
Since, I have had to get myself tucked back in the trunk with my arm once again reaching into the abyss. I figured that I best not do what I did the last time. This time I put my phone where I could easily reach it and I also didn't do that extra reach into and over the wheel tub. So I think I learned my lesson and next time I might even take a pillow in with me.
marty-mj
Old 02-11-2022, 06:33 PM
syborg tt's Avatar
Since, I have had to get myself tucked back in the trunk with my arm once again reaching into the abyss. I figured that I best not do what I did the last time. This time I put my phone where I could easily reach it and I also didn't do that extra reach into and over the wheel tub. So I think I learned my lesson and next time I might even take a pillow in with me and maybe some snacks.
marty-mj
camcojb (02-11-2022)
  #1770
Old 02-11-2022, 06:41 PM
syborg tt's Avatar
Default Thank God for Mike ( 01-19-22 )
I talked to Mike earlier in the week and once again he came to the rescue to add the helping hand. He also brought the his
assortment of 3/8's hose clamps as I needed a few to plumb the fuel tank vent.
Of course I picked the really cool spring clamp one.
Tanks ready and going in !!!
I think I said " Don't Scratch the Tank " at least twenty times before I carried it over. I hope the "Hello Kitty Towels" protect it.
Tank is in and we didn't scratch it.
Next up I need to find the filler neck.
marty-mj
fleetus macmullitz (03-31-2022)
