Old 03-16-2022, 10:52 AM
colorado80439 colorado80439 is offline
The Following 3 Users Say Thank You to colorado80439 For This Useful Post:
Bobsky (03-19-2022), camcojb (03-16-2022), Ketzer (03-18-2022)
  #582
Old 03-26-2022, 09:33 AM
andrewb70's Avatar
Originally Posted by 68454RS View Post
Andrew, is this not the same as what you did with my Term X and my Spal brushless? Or something completely different and I should delete this.. lol
When using the brushless fan with the built in controller, you can go directly from the Holley to the fan signal wire.
Andrew
Instagram @dr__efi
I deliver what EFI promises.
My YouTube Channel
Old 11-20-2022, 04:18 PM
68LS1's Avatar
68LS1 68LS1 is offline
Can someone confirm the part number for suitable fans to use with Holley EFI
What are the suitable fan options? C7 Corvette and any thing else.
This is for my 71 Blazer, but may also update on my 72 C10
thanks
Roger
68 RS Camaro Convertible LS1 6 speed
72 C10 SWB Stepside, old skool 350 4L60e
71 K5 Blazer 350sbc T350
Old 11-20-2022, 06:40 PM
andrewb70's Avatar
thanks
There are many brushless fans that will work with the Holley EFI. It would be helpful to know the size of the core of the radiator you are using. On my 70 GTO I am using the dual Chevy Volt fans that fit the 26x18X core very nicely.
Andrew
Instagram @dr__efi
My YouTube Channel
The Following User Says Thank You to andrewb70 For This Useful Post:
camcojb (11-21-2022)
  #585
Old 11-20-2022, 09:47 PM
68LS1's Avatar
Andrew
The core size is 16-1/8" H x 28-3/8" W. I have a preference to run a single fan
Will be using a Holley Terminator Stealth
Roger
Old 11-21-2022, 08:52 AM
andrewb70's Avatar
The C7 fan should fit your core nicely and will work very well.
Andrew
Instagram @dr__efi
My YouTube Channel
  #587
Old 11-21-2022, 07:05 PM
68LS1's Avatar
Andrew
Is this the one I should order, Part No 84486698?
https://sdparts.com/i-24135048-genui...iator-fan.html
thanks
Roger
The Following User Says Thank You to 68LS1 For This Useful Post:
dhutton (11-22-2022)
  #588
Old 11-21-2022, 07:57 PM
andrewb70's Avatar
thanks
That is the one...
Andrew
Instagram @dr__efi
My YouTube Channel
  #589
Old 07-05-2023, 04:42 PM
flyingv's Avatar
flyingv flyingv is offline
For any of you with an E67 from an 09' vehicle, here is what changes I made to finally get the C7 PWM fan to work.
1. I changed the OS from 09' CTS-V to an 09' ZR1
I did confirm through a document on the EFI Live forum that the 2 OS's are compatible.
*no matter what i did with the CTS-V calibration, I could not get a output signal from X3-49*
2. I changed fan settings to PWM Electric 100hz
*PWM EV 100hz did not work per the C7 calibration*
3. Fan State vs. Desired (all zeroes)
4. Output State vs. Control (all 1's)
5. Wired in AC pressure sensor @ X3-21, X3-57, & X3-37
Viola! PWM fan control works in the scanner!
The Following 3 Users Say Thank You to flyingv For This Useful Post:
camcojb (07-06-2023), cpd004 (07-07-2023), dhutton (07-06-2023)
  #590
Old 07-05-2023, 07:19 PM
andrewb70's Avatar
2. I changed fan settings to PWM Electric 128hz
Good information. Nicely done.
Andrew
Instagram @dr__efi
My YouTube Channel
