Old 08-13-2022, 07:48 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
I expected the paint to come off like the primer and surface rust. Pulling the drum across it felt more like dragging a knife through a bar of clay and it kind of piled up like it was being pulled. I expected it to be hard. It's not thick, but thicker than expected.
That's as far as I got for today. I need to clear the parts out of the car and remove the door handles/locks. Probably be a few before I get after it again.
Thanks for looking!
Curtis
Old 08-13-2022, 08:14 PM
Spiffav8's Avatar
Lateral-g Moderator
What is this "roller" you speak of?
This is a full size one.
This is 1/4 size for getting into smaller areas. Burned through the first one pretty quick with all the sharp edges on the fire wall.
I looked it up. Eastwood calls it a drum. Makes more sense.
Curtis
The Following User Says Thank You to Spiffav8 For This Useful Post:
camcojb (08-13-2022)
  #53
Old 08-14-2022, 07:03 AM
Ketzer's Avatar
Ketzer Ketzer is offline
Drum stripping is some serious work but that finish is so gratifying!!
Looks like they skim coated the entire door with filler previously? I see it a lot on social media, I guess that's common to get all the panels even?
Be sure to check with your paint guy before you put anything on that bare metal to keep it from flash rusting again... I understand that silicone products are a big no-no.
Jeff-
The Following User Says Thank You to Ketzer For This Useful Post:
Spiffav8 (08-14-2022)
  #54
Old 08-14-2022, 10:43 AM
The finish of that stripper wheel looks fantastic. Very professional. Much like how DSE finishes their metal work. The stellar results I’m talking about.
The Following User Says Thank You to Jimbo1367 For This Useful Post:
  #55
Old 08-14-2022, 03:02 PM
Spiffav8's Avatar
Lateral-g Moderator
Jeff-
Sent the pics to a few body guys and they all said it’s older bondo like product. Talked to Joe at Dutchboys and Brycen about protecting the metal after stripping it. Both said to use GIBBs.
Originally Posted by Jimbo1367 View Post
The finish of that stopper wheel looks fantastic. Very professional. Much like how DSE finishes their metal work. The stellar results I’m talking about.
Yeah it’s crazy. Very satisfying!
Curtis
The Following 2 Users Say Thank You to Spiffav8 For This Useful Post:
camcojb (08-14-2022), Ketzer (08-14-2022)
  #56
Old 08-14-2022, 10:10 PM
Spiffav8's Avatar
Lateral-g Moderator
It was seriously hot today and humid for Las Vegas. No idea how anyone survives in places like Georgia this time of the year. I may need an intervention as this is all I want to do. I definitely could use an IV after working in the garage today. Lot of clean up work!
Finished stripping the top half of the door, sail panel and then went after the passenger side rear quarter. Also hit the drivers side again.
Curtis
The Following 3 Users Say Thank You to Spiffav8 For This Useful Post:
camcojb (08-15-2022), colorado80439 (10-15-2022), Roscoe03 (08-16-2022)
  #57
Old 08-15-2022, 05:58 AM
dhutton dhutton is offline
Are you still planning to dip the car?
Old 08-15-2022, 02:05 PM
Spiffav8's Avatar
Lateral-g Moderator
Yes for a few reasons. After the fight with the filler on the door I hit a small area on a few other parts to see if it was partial repaint, but it's everywhere. There are tight spots/spots I cant get into and I want everything clean and protected. Whatever it is they use on the back side of the front fenders doesn't look like fun trying to remove. The dipping process will remove everything. Additionally they apply a rust inhibitor that will help protect the body and parts till it's able to get into the paint shop.
Curtis
dhutton (08-15-2022)
  #59
Old 08-16-2022, 09:51 AM
You’re doing it right. Great work!!!!
Old 08-16-2022, 12:13 PM
fleet's Avatar
fleet fleet is offline
How’s the shoulder holding up, Bruh?
