Old 12-07-2021, 08:43 AM
dhutton dhutton is offline
Originally Posted by andrewb70 View Post
What exactly does the input do?
Andrew
The top of clutch switch is used as in input to the ECM to briefly disable fuel when the clutch is depressed, which helps decelerate the engine and makes upshifting easier and quicker.
fleetus macmullitz (12-11-2021)
  #882
Old 12-07-2021, 11:27 PM
CarlC CarlC is offline
It is the production Camaro throw out bearing
Gen4 LS F-body or??? That's what I've been using with good results.
http:www.vaporworx.com
Old 12-11-2021, 11:01 AM
Stielow's Avatar
Stielow Stielow is offline
Is the OEM throwout bearing used or the Tilton? I'm pretty skeptical on non-OE/non-preloaded TOB's but Tilton swears by their part.
Yes LS 4th Gen. Stock. Works good.
Stielow Engineering
CarlC (12-12-2021)
  #884
Old 12-18-2021, 07:18 AM
Number1 Number1 is offline
Default Intercooler pumps
What does the c7 ZR1 intercooler pumps flow compared to others?
Old 12-18-2021, 08:46 AM
srode1 srode1 is offline
here's a chart comparing a few including the ZR1
https://fiinterchillers.com/tech_art...sting-results/
The Following User Says Thank You to srode1 For This Useful Post:
camcojb (12-18-2021)
  #886
Old 12-18-2021, 11:06 AM
Jr's Avatar
Jr Jr is offline
The new mufflers are "Hot Rod" quite. I am still looking for something quieter, but I'm getting old and I am tired of loud cars. I have tinnitus from all the louds stuff I have done all my life. I want my hot rods to be quieter.
Mark
Are you running borla or black heart mufflers?
Old 12-18-2021, 05:00 PM
Stielow's Avatar
Black Heart.
Stielow Engineering
kwhizz (12-19-2021)
  #888
Old 12-19-2021, 05:07 AM
130fe 130fe is offline
Post
Black Heart.
Mark, I am running the blackheart mufflers on my 68 (Holleys entire system for the Quadralink). I am getting an annoying exhaust drone from about 2-2400 rpm no matter what speed/gear. Are you getting the same?
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 08-18-2022, 06:05 PM
CraigP CraigP is offline
Default Alloy Diff Centre
Phenomenal build thread Mark!
I spent a good couple of hours going through it.
I have a question regarding your experience with alloy housings. I’m building a Pro Touring 1967 Fairlane hardtop, it’ll weigh around 3200lbs, have around 600hp and run a 6-speed, plus a pretty decent tire (315/30R18) on the back. Predominantly an occasional weekend toy with probably 3-4 track days (circuit) a year.
Strange talk about reduced life on the gears due to housing flex. Strange Engineering also did not recommend their alloy centre due to the weight – yet I’ve seen a host of cars running alloy centres. You’ve used them and have beat on them pretty hard – what’s been your experience?
Thanks in advance
Craig P
Old 08-20-2022, 12:10 PM
Over on YouTube, Lawrence LT Tolman has a how to video on this very subject.
The video is from Feb 17,2022, titled “ using SCIENCE to ELIMINATE exhaust drone: I finally did it!.
Hope it helps.
The Following User Says Thank You to Jimbo1367 For This Useful Post:
camcojb (08-20-2022)
