Old 10-04-2022, 03:04 PM
ProTouring442's Avatar
Default 302 Windsor Build Pre-planning
Planning out a build to go in my 1987 Mustang LX (5-speed).
Bottom end: a stock rebuild
Heads: Twisted Wedge 11R 170CC/53CC
Rockers: Crower's shaft-mount
Cam: Trick Flow HR-236/359-2S1-10
Lift @ valve: 0.542 int./0.563 exh.
Dur @.050: 224° int./232° exh.
Lobe Separation: 112°
Intake option 1: Holley Systemax
Intake option 2: Speedmaster ITB
Exhaust option 1: BBK Long Tube
Exhaust option 2: Equal Length Shorties
Oil Pan: AVIAID Road Racing
Engine Management: Pro-M
Use: Mostly spirited driving. Kind of an 80s GT350
Chassis Info: Maximum Motorsports torque arm, Bilstein HD shocks & struts, Cobra brakes, etc.
Differential: 3.73:1
Thoughts? I'd like to make in the 350hp range, I think.
Never met a man with real talent who felt the need to deride the efforts of other.
Old 10-05-2022, 07:05 AM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Default Steeda 18 FTW
I had the B303 (224/224 @ 110 LSA) and the Steeda 18 (220/226 @ 112 LSA) in my 1990 GT with the e-heads RPM (251 @ 500 lift) & e-intake with the stock 302 bottom end.
I personally think you'd be happier with something like a 220-226 @ .050 on a 112 or 110 LSA. If it were mine I'd go with the Steeda 18 again (220/226 @ 112 LSA) or a XE262H (218/224 @ 110 LSA) would be also be a good option for a 302 imho.
Again, just my humble opinion but to take advantage of the 224-232 cam you'll need more cubic inches... more cubes would also make better use of those TFS heads which flow around 250 @ 28"... now would be a good time to do a 331 or 347 stroker! I'd prefer the 331 for the shorter stroke and reduced side loading. (exactly why my Pontiac 400 is now a 440cid stroker).
Anyway, my 90 GT 302 with the Steeda 18 ran an 11.93 back in the day fwiw... before I add the Paxton supercharger. e-heads & intake, Steeda 18 and BBK headers/x-pipe/exhaust. HTH
You'll hit your 350hp mark... 300hp to the tires with the 5-speed is a lot of fun in a Fox body!
p.s. I'd run 3.55 rear gears if it were mine and I wasn't looking for every 10th in the quarter.
Ty Ingle, USAF Retired
FREEDOMBIRD
The Following User Says Thank You to OLDFLM For This Useful Post:
ProTouring442 (10-05-2022)
Old 10-05-2022, 12:34 PM
All good food for thought, thank you!
I'm inclined to agree with you on the gearing, but the car is currently equipped with the 3.73s, so for now...
Also, the bottom end has already been rebuilt, so I was just going to start with that. A high-revving 302 sounds like a blast, hence my cam choice. It's also why I'm considering the ITBs. They should smooth out the larger cam.
I'm also thinking of eventually going with a 6-speed.
Hmmm...
