Old 12-11-2022, 06:04 AM
need help need help is offline
Default CARB GUY
Going to Fast 303000 multiport. I'm 74 so may need help from time to time. Got off FB, was a lot of help there. Thanks for letting me join
Old 12-11-2022, 08:52 AM
camcojb camcojb is online now
Welcome to the site. There's several guys here who've used FAST, should be able to get you through the process. That kit isn't a complete swap kit, so you'll still need a throttle body, fuel system, injectors/rails depending on intake manifold, etc.
Old 12-11-2022, 07:37 PM
572Camaro's Avatar
Welcome to Lat-G.
I want to help in any way I can.
I installed a FAST XFI. Version 2.05 in sequential mode on my 68 Camaro.
I have completed some minimal tuning and attended EFI University by Brian Macy.
My problem is that was almost a decade ago.
But please tell us a couple things to better understand your situation.
Camshaft lobe separation angle.
Type of intake.
Distributor plans.
ECU mounting location.
Thanks for joining. This forum teaches me everyday
Old 12-12-2022, 08:04 AM
Default beginning XFI Sportsman hook up
Have it all laid out, not much terminated. Do have the TPS, water temp sensor, all multiport plugged in. Also have the program installed on lap top. 572 RB world block with Hogan intake and 2 Accufab 90s. solid roller >In .727, Ex .706, @.050 283, 292 lobe sep 112 in c/l 108. Auto 727w gear Vendor hooked to Strange custom 3:89 in a 66 Charger.
303000, dist is XDI 305013, E-6 ign box .Trying to add pics, no luck need help there will not allow me to copy and paste, put the file number still no luck. will ask a few simple questions later (am not a 12 volt guru for sure )
Old 12-14-2022, 08:18 AM
syborg tt's Avatar
Good Morning,
I received your private message asking how to post pictures on the forum. It's much different from posting on Facebook. You will need to know where the pictures are on your hard drive and then look for them.
While you are creating your post you will have the option to make change above this block you are typing in.
"Orange Arrow ''
Then highlighted the ''Paperclip" in red. Click on that and the manage attachments will come up.
Select Choose File ''Highlighted in blue'' and then click upload
marty-mj
The Following 3 Users Say Thank You to syborg tt For This Useful Post:
572Camaro (12-19-2022), camcojb (12-14-2022), need help (12-15-2022)
Old 12-14-2022, 10:46 AM
Good Morning,
Should just make you a moderator lol.
The Following 2 Users Say Thank You to camcojb For This Useful Post:
need help (12-15-2022), syborg tt (12-14-2022)
Old 12-14-2022, 12:01 PM
syborg tt's Avatar
I had a little free time this morning so I figured I would help
marty-mj
camcojb (12-14-2022), jarhead (03-13-2023)
Old 12-15-2022, 03:26 AM
Thanks so much for your time and help, was trying to use the image instead of paper clip, so hope to try it again :-)
Old 12-15-2022, 04:01 AM
572 RB with Hogan intake and a pair of Accufab 90s to feed the multiport, using FAST distributor dual sync as well plus sadly now defunct E-6 ign box. still in box, FAST says no parts available so quit building them. Sadly FAST only has about 5 tech guys vs 15 before Edlebrock bought them. (coincidence) hmnnnnnnnnn. Always very helpful when I do get through but the wait can be awhile
Old 12-15-2022, 09:42 AM
The image box works fine, but the picture has to be hosted on the net. You just click the box and then copy/paste the link and the pic pops up.
We added the attachment feature for those who wanted to post pics directly from their computer/phone/tablet.
