Old 02-17-2023, 03:33 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
This thread never disappoints.
Curtis
The Following User Says Thank You to Spiffav8 For This Useful Post:
Goosesdad (02-20-2023)
  #622
Old 02-18-2023, 06:53 AM
68454RS's Avatar
68454RS 68454RS is offline
Agreed
The Following User Says Thank You to 68454RS For This Useful Post:
  #623
Old 02-20-2023, 09:37 AM
Goosesdad's Avatar
A bracket with Rivnuts, welded to the door. The door panel slides over it and then when the armrest bolts on, it pulls the panel in tight so it doesn't rattle.
With the armrest installed.
Looking up from the bottom of the armrest.
Backside of armrest.
Same process of sealing up the front armrest extension.
Have a great day!
John
My Build Thread:
The Following 6 Users Say Thank You to Goosesdad For This Useful Post:
camcojb (02-20-2023), colorado80439 (03-12-2023), dhutton (02-20-2023), fleetus macmullitz (02-20-2023), jarhead (02-28-2023), syborg tt (07-31-2023)
  #624
Old 02-21-2023, 11:18 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Excellent craftsmanship!!
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Goosesdad (02-23-2023)
  #625
Old 02-27-2023, 07:39 PM
Ricochet's Avatar
Ricochet Ricochet is offline
This things continues to be another level! Well done!
Brent
Old 02-28-2023, 08:51 AM
Goosesdad's Avatar
Thanks guys!!!
Have a great day!
John
My Build Thread:
Old 02-28-2023, 09:59 AM
Goosesdad's Avatar
2 steps forward...1 step back. No fun if we don't share the mis-steps.....
I struggled with the look of how the arm rest cut off the speaker at the bottom but I really like the how the arm rest sits on top of the door bar when the door is closed. It really looks good when you are inside with the door closed. Probably making a big deal out of a non-issue, but thought a little return on that speaker opening might finish off the look. It didn't work, as you can see. Looks bad and while I knew I was going to have to modify the speaker grill, it just made that fit way to tight.
Cutting that lower section off today and going back to just letting the arm rest do it's thing. Once it's covered with black leather, it will mostly disappear anyway.
Here is the driver door with the arm rest done. I'll make the pass side like this today.
The door pull will get done black later but just had to ditch the blue anodizing now! Easy Off oven cleaner eats it quick. Definitely doesn't leave a pristine Al finish so I wouldn't count on it if you want useable bare Al but good enough for just removing the anodizing.
The two right most metal brackets are welded to the door so they solidly anchor the armrest and make for no flexing when the door is pulled closed.
Somehow drilling 6 holes in that metal bracket makes it lighter!!
Have a great day!
John
My Build Thread:
The Following 3 Users Say Thank You to Goosesdad For This Useful Post:
Ricochet (03-05-2023), Spiffav8 (03-02-2023), syborg tt (07-24-2023)
  #628
Old 03-06-2023, 09:34 AM
Goosesdad's Avatar
Arm rests completed. The inside of the door pull area will get covered with leather so I smoothed it so your fingers don't bump square edges.
Made the upper section flow into the door panel. Used plastic welder (super hot soldering iron) and shaped these areas. And filled the door lock hole. All will be covered leather.
Underside.
Have a great day!
John
My Build Thread:
The Following 4 Users Say Thank You to Goosesdad For This Useful Post:
camcojb (03-06-2023), dhutton (03-07-2023), Roscoe03 (03-14-2023), syborg tt (07-24-2023)
  #629
Old 03-06-2023, 10:23 AM
Old 03-09-2023, 03:19 AM
MODO Innovations's Avatar
Very nice!!!
Shannon
Modo Innovations
940-391-9002
