Old 03-12-2023, 11:04 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
I'm loving the door panel design.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 03-22-2023, 03:28 PM
Goosesdad's Avatar
Originally Posted by MODO Innovations View Post
Very nice!!!
Thank you!!!!
Have a great day!
John
My Build Thread:
Old 03-22-2023, 03:48 PM
Goosesdad's Avatar
Finishing the center console. I wanted to use some factory parts as the basis of design here. Not sure I would do this again as blending plastic, fiberglass and MDF presents some challenges that most obviously just solve by doing this out of metal. But I'm down the path so I'm sticking with it.
All of this will get covered with leather but one of the problems I haven't been able to solve is getting any glues or filler to stick to this plastic. I've been using a plastic welder and plastic filler rod which works great for getting the general shape down but smoothing is difficult. Would be great to use body filler but it doesn't stick. I've tried every version of plastic glue I could find. Nothing sticks, might as well be putting the glue on wax cause it just peels off.
Not a real big deal as the leather will hide most of the imperfections, just would make shaping this easier.
Started a while ago with some used parts sourced from the junkyard and some new (cup holders) from eBay. Morphing it all together over the next few weeks.
I built that rear piece (gray) long ago. The EStopp is under that area.
Started a little storage area under the waterfall.
Beginning the waterfall.
Here is the start of changing the center console shape. Started with the swoop (drivers side) and modified it to go straight. This will make sense later but you can see where the plastic welder was used to reweld the section flat after I cut it and then used heat to flex it flat. The welding process works real easy but as you can imagine, the plastic doesn't sand very well so smoothing it would be awesome with some filler. Anyone have any thoughts?
Have a great day!
John
My Build Thread:
The Following 3 Users Say Thank You to Goosesdad For This Useful Post:
fleetus macmullitz (03-22-2023), syborg tt (07-31-2023), waynieZ (05-01-2023)
  #634
Old 03-22-2023, 04:22 PM
CJD Automotive's Avatar
CJD Automotive CJD Automotive is offline
Really liking how this is turning out.
Back in the day, we used to take shavings from the parent material and add them to a cup of acetone. Acetone melted the abs and made a slurry past. You then wiped that on as a filler. You need to burn a small sliver and see what type of plastic it is. There are charts online that tell you by the flame color or smoke what type of plastic it is, I can't remember off the top of my head. If it is ABS, the other option is a two part Fusor epoxy for ABS, but that gets real expensive, quick.
Craig Scholl
CJD Automotive, LLC
www.CJDAUTOMOTIVE.com
"I own a Mopar, so I already know it won't be in stock, won't ship tomorrow, and won't actually fit without modification."
The Following 2 Users Say Thank You to CJD Automotive For This Useful Post:
syborg tt (07-31-2023), zz430droptop67rs (03-22-2023)
  #635
Old 03-23-2023, 09:46 AM
Goosesdad's Avatar
Thanks Craig!!! Will try.
Have a great day!
John
My Build Thread:
The Following User Says Thank You to Goosesdad For This Useful Post:
  #636
Old 05-01-2023, 11:33 AM
Goosesdad's Avatar
Mold for the extension of the center console underway. Of course the PVC and the rest will get discarded after the 'glass work......next weekend.
Have a great day!
John
My Build Thread:
The Following 5 Users Say Thank You to Goosesdad For This Useful Post:
214Chevy (05-01-2023), colorado80439 (05-25-2023), dhutton (05-07-2023), syborg tt (07-24-2023), waynieZ (05-01-2023)
  #637
Old 05-01-2023, 02:13 PM
214Chevy's Avatar
Super nice...I can see the vision.
'68 C10 swb
'72 Chevelle
Goosesdad (05-02-2023)
  #638
Old 05-09-2023, 03:30 PM
Goosesdad's Avatar
Just some chip board for the backing of the make-shift mold. The PVC's diameter is exactly perfect such that after the glass is laminated, the overall diameter will match the plastic center console. Once covered, this should all flow together with just a seam between them.
Hard to see because I used surfboard resin which is clear - but 2 layers of 1 1/2oz of fiberglass mat laid down. No real reason for using this resin, just have a bunch of it from some Carbon Fiber projects.
Have a great day!
John
My Build Thread:
The Following 2 Users Say Thank You to Goosesdad For This Useful Post:
syborg tt (07-24-2023), WSSix (05-11-2023)
  #639
Old 05-15-2023, 07:57 AM
Goosesdad's Avatar
Kick panels laminated.
Have a great day!
John
My Build Thread:
camcojb (05-15-2023), syborg tt (07-24-2023)
  #640
Old 05-15-2023, 09:52 AM
Very nice work John!
Goosesdad (07-05-2023)
