07-05-2023, 03:58 PM
I know all of this looks super rough but thought sending some of the process would be enjoyed. Not promising perfection but fine tuning is coming soon.
Everything that is currently wood (dash and lower dash panels) are just "plugs", I will make fiberglass molds of these plugs and then make proper fiberglass parts as the final piece.
Made a quick cardboard template of the glove-box-delete panel and intended to make a wood mold from that....the cardboard ended up straight and stout enough that I decided to skip the wood mold process for this very simple part.
Some radius work with filler.
A splash of filler primer for a final sanding.
2 layers of 1.5oz mat and 1 layer of cloth.
Fast forward quite a bit and have this panel mounted in place. Fair bit of work to get the flanges to hold this piece. Still lots of clean up to be done but making this panel easy to access and remove was important as I'm going to mount some electrical behind it..
And really paying attention to the panel gaps here to account for .090 for 2 layers of leather or alcantera - keep the interior guys from hating me later.
Taking every opportunity to keep ingress/egress for your feet at least reasonable without being a yoga instructor. Not much room with the door bars but compromise is always part of our lives!
Pulled the passenger side of the center console off it's mold so I could reinforce some of the sections.
The Following 6 Users Say Thank You to Goosesdad For This Useful Post:
07-05-2023, 06:51 PM
This is like magic for me. Amazing.
The Following 3 Users Say Thank You to dhutton For This Useful Post:
07-22-2023, 03:54 PM
Thanks Don.
07-22-2023, 04:03 PM
More of the process; getting the flanges for the glove box delete panel all spaced properly so the gaps will be correct when the real parts get covered.
The glove box panel and the center console sides are the final parts, all others will get molded and lightweight parts made from there. Soon.
The fuse block will be accessible behind this panel so it needed to be easily removed.
Was a balance of making the panel cover as much of the evap as possible but still leaving some room to swing your feet through.
The Following 7 Users Say Thank You to Goosesdad For This Useful Post:
07-29-2023, 10:53 PM
07-29-2023, 10:59 PM
07-30-2023, 07:46 AM
Nice work, looking good!
Corey
1989 Camaro RS
07-30-2023, 07:56 AM
Yep, absolute Wizardry
07-31-2023, 08:39 PM
The interior is really taking shape and I am looking forward to seeing covered in leather.
08-05-2023, 08:23 PM
Looking great man. Love the progress.
