Old 07-06-2023, 07:57 PM
flyingv's Avatar
flyingv flyingv is offline
Update
When I commanded the fan on in the VCM scanner, the fan would come on and ramp up as I increased the percentage. However, when I would lower the percentage the fan would stop, and not restart until I cycled the ignition off/on.
So I went back into the calibration and switched the hz setting to 100 on a chance.
Now the fan runs perfect. Moving up or down on the fan control works like it should in scanner.
Thanks again to everyone in this thread for all the informative posts!
Sent from my SM-S906U using Tapatalk
The Following 2 Users Say Thank You to flyingv For This Useful Post:
andrewb70 (07-06-2023), camcojb (07-07-2023)
  #592
Old 07-06-2023, 07:59 PM
andrewb70's Avatar
Originally Posted by flyingv View Post
Update
Everywhere I read indicates that the modern brushless fans use 100Hz.
Andrew
Instagram @dr__efi
I deliver what EFI promises.
My YouTube Channel
The Following User Says Thank You to andrewb70 For This Useful Post:
  #593
Old 11-03-2023, 05:38 PM
*rayman*'s Avatar
*rayman* *rayman* is offline
where's the best place to buy 2 x SPAL VA89-ABL320P/N-94A fans now. Seems to be very few places to purchase from.
Also noticing the same part number coming up on alibaba now, look identical without the silk screened SPAL logo. Anyone tried these?
68 BB SS Camaro - building it in Australia, where everything costs twice as much as it costs in the U.S.
Fuel prices suck!
Old 01-09-2024, 12:05 PM
SCP Auto SCP Auto is offline
Originally Posted by andrewb70 View Post
Thanks for chiming in! Please keep this thread updated. I know from another LT4 build that the stock GMPP fan configuration is discrete fan control, with a Hi and Low fan setting. PWM would be way better, especially if you're using the new CTSV 800watt fan.
Have you found a source for the Yazaki connector and terminals for the fan?
Andrew
Hello did you find a way to use GMPP E92 to run the cooling fans with PWM
Old 01-18-2024, 06:42 AM
samckitt's Avatar
samckitt samckitt is offline
For any of you with an E67 from an 09' vehicle, here is what changes I made to finally get the C7 PWM fan to work.
1. I changed the OS from 09' CTS-V to an 09' ZR1
I did confirm through a document on the EFI Live forum that the 2 OS's are compatible.
*no matter what i did with the CTS-V calibration, I could not get a output signal from X3-49*
2. I changed fan settings to PWM Electric 100hz
*PWM EV 100hz did not work per the C7 calibration*
3. Fan State vs. Desired (all zeroes)
4. Output State vs. Control (all 1's)
5. Wired in AC pressure sensor @ X3-21, X3-57, & X3-37
Viola! PWM fan control works in the scanner!
Did you use EFI Live or HPTuners to change the OS?
Will it work without the AC pressure sensor or is that required?
Thx
Scot
86 Monte SS
LS2/T56 Magnum
Old 01-18-2024, 06:00 PM
flyingv's Avatar
I used Hptuners to do the OS swap. I do have the AC pressure sensor wired. I don't see why it wouldn't work without it.
The Following User Says Thank You to flyingv For This Useful Post:
camcojb (01-18-2024)
  #597
Old 01-21-2024, 05:37 AM
samckitt's Avatar
Where did you get the ZR1 OS file? Thanks
Scot
86 Monte SS
LS2/T56 Magnum
