Old 07-14-2023, 12:32 PM
syborg tt's Avatar
What can I say it's hard finding free help these days
Broh,
Yer in Chicagoland, workin with the one-armed man…just be careful out there.
marty-mj
fleetus macmullitz (07-14-2023)
  #2162
Old 07-15-2023, 05:41 AM
syborg tt's Avatar
Default Intake Tube Support Bracket & Final Cuts (( 07-04-23 ))
Next up I am going to finally finish working on the intake tube support bracket.
I know it looks complete however the tubes are shoved way far into those hump hoses. So I will need to remove a some of the material.
I marked where the hump hose ends so I know how much that I need to remove.
Well after 30 years it's finally time to retire my old Dremel
In with the new
Time to make the first cut
Just a little bit of clean up.
One Hour later and "Look mom nothing changed"
I will be dropping these off at the Powder Coater tomorrow.
marty-mj
The Following 4 Users Say Thank You to syborg tt For This Useful Post:
camcojb (07-15-2023), fleetus macmullitz (07-16-2023), Goosesdad (07-15-2023), Roscoe03 (07-17-2023)
  #2163
Old 07-15-2023, 05:49 AM
syborg tt's Avatar
Default Door Pull - Plan B (( 07-03-23 ))
I am finally working on the door pull concept do to the door bars.
If you look the distance between the factory holes is about 1" shorter which should work perfect.
I am hoping they will sit right above the Tiger Cage Door Bars.
old picture for reference
marty-mj
The Following 3 Users Say Thank You to syborg tt For This Useful Post:
camcojb (07-15-2023), fleetus macmullitz (07-15-2023), Goosesdad (07-15-2023)
  #2164
Old 07-15-2023, 07:51 AM
syborg tt's Avatar
Default Harness Bar (( 07-03-23 )) - After Dinner with my Wife
Remember no matter how small the project is getting just one of them done when you only have an hour.
It's still a completed project.
Thankfully, I used the blue tap as reference marks so it was a simple project.
Tin Man **** !!!
Done and now a quick shower and off to dinner with Mike & his wife.
marty-mj
The Following 5 Users Say Thank You to syborg tt For This Useful Post:
68454RS (07-15-2023), camcojb (07-15-2023), fleetus macmullitz (07-16-2023), Goosesdad (07-15-2023), Roscoe03 (07-17-2023)
  #2165
Old 07-15-2023, 08:00 AM
68454RS's Avatar
68454RS 68454RS is offline
Even the little things need to get done.. wish I could find a Tiger Cage for my 68
The Following User Says Thank You to 68454RS For This Useful Post:
syborg tt (07-15-2023)
  #2166
Old 07-15-2023, 08:52 AM
syborg tt's Avatar
and they always seem to take more time then you think.
Did RideTech stop making the Tiger Cage ??
marty-mj
68454RS (07-16-2023)
  #2167
Old 07-16-2023, 07:40 AM
syborg tt's Avatar
Default Swapping out the Fan Fuse (( 07-04-23 ))
Another simple project that took much longer then I expected.
Swapping out the fuse for a circuit breaker.
I love using these washer for grounds on sheet metal.
I needed to borrow the Rubber Booty & the nuts from one of the other circuit breakers. Next car show I go to I am going to buy more of them.
Mounted
I sleeved the wire with the Tech Flex Abrasion wrap just because it looks better and offers great wire protection.
I use this little trick to make sure I know exactly where the heat shrink needs to start.
My OCD is Killing me
Yep, I have issue's
Being honest I was convince I cut the wire short and thankfully I did not.
Everything I used today just to run one wire.
marty-mj
camcojb (07-16-2023), fleetus macmullitz (07-16-2023)
  #2168
Old 07-16-2023, 11:21 AM
syborg tt's Avatar
Default Every little project gets me closer (( 07-04-23 )) PM
After dinner I ran out to the garage since I had about an hour before I was going to call it a night. ( Going to Dinner with the Wife ))
It's full
Not sure if I am going to use both door pulls on the car but I have the second set just in case.
marty-mj
  #2169
Old 07-16-2023, 11:37 AM
syborg tt's Avatar
Default Intake Tube Support Bracket (( 07-09-23 ))
Since the intake tube is just literally just hanging off the throttle body I need to finish the support bracket.
I have desire to remove the fan shroud to make holes so Self-Taping screws to the rescue.
I can't seem to find my 1/4" adapter for my drill so I am going to improvise.
Since the cardboard bracket won't be strong enough I am going to run over to High Speed Welding after work
tomorrow and have him make me an aluminum version.
yep, the screw is just short enough.
Well, I didn't notice it was crocket till I pulled the tape off.
Oddly enough the tube runs up on a slight angle to it works perfect
It's hard to see but there are rubber grommets the bolts go through so I will be using Nylock Nuts so I don't have to
worry about them coming loose. You can also see the bolt that is on the intake tube that I will be using to secure
the intake tube to the bracket.
I am going see if I can find a shorter nut as it doesn't need to be this thick.
Looks like everything worked so off to the powder coater we go.
marty-mj
camcojb (07-16-2023), fleetus macmullitz (07-16-2023), waynieZ (07-16-2023)
  #2170
Old 07-16-2023, 06:06 PM
$mike70Z28's Avatar
$mike70Z28 $mike70Z28 is offline
HEY, Marty where did you get the fender cover ??? what is the underneath made for scratches ???
The Following User Says Thank You to $mike70Z28 For This Useful Post:
syborg tt (07-27-2023)
