Old 09-01-2023, 02:03 PM
Simple solution and kinda hidden, I like it.
syborg tt (09-03-2023)
  #2242
Old 09-03-2023, 08:55 PM
syborg tt's Avatar
Default Wheels to Adam (( 08-31-23 ))
Well I removed a couple things off the table today.
The wheels are heading over to Adams to get Ceramic Coated.
marty-mj
camcojb (09-04-2023)
  #2243
Old 09-03-2023, 09:05 PM
syborg tt's Avatar
Default Wheels are Coated (( 09-01-23 ))
Adam texted this picture of the wheels
All better and coated
marty-mj
waynieZ (09-16-2023)
  #2244
Old 09-03-2023, 09:32 PM
syborg tt's Avatar
Default Final Battery Ground Cable (( 09-02-23 ))
Time to build the final ground wire and I have way to many wiring connectors.
While the mock up battery was in the car I estimated the cut length of the cable.
Looks good
This was the point when I should have swapped to the Black Anodized tray.
Confirming
Crimping with my helper.
Heat Shrunk cable end.
Confirming the gap.
I enlarged the holes to allow some wiggle room.
Time to make some battery bolts. You can see that I used a shouldered nut and grimmped that in the vice and then I installed
the bolt and tightened it. At this point I can cut the bolt and not damage the visible nut.
I also shortened the acorn nut to it didn't poke into the bottom of the battery case.
Since the negative cable is close to these two nuts I swapped them out.
Much better looking and of course they won't damage the ground wire.
If you look at the ground wire you can see I wrapped it in DEI Abrasion wrap.
Tray is in.
Support Rod is in.
marty-mj
fleetus macmullitz (09-04-2023)
  #2245
Old 09-03-2023, 09:44 PM
syborg tt's Avatar
Default And yet there is more !!! (( 09-03-23 ))
Final Battery Bolts !!!
This is the hardware I will be using on the battery hold down brackets and I will be using star washers on all of the bolts.
I need to swap out the bolt circled in red as it will be supporting the AC line.
Enlarging the holes so I don't have to go to Home Depot !!!
Test Fitting
AC Hose secured.
The area circled in red was bent into the engine compartment and it sure did look like it was going to eventually cut through
the ground wire. So I gently bent it flat and added some black touch paint.
I also put a note reminding me that there is a Nylock nut on the other side.
I ended up going Hi-Vis
More star washers and I also confirmed that the longer bolts would not poke through the bottom of the battery tray.
I installed the bracket and tightened prior to installing the battery.
I really hope this is the last time I have to lift this battery.
Ugh, I need to remove a little bit of plastic.
Thankfully the utility knife worked.
It's in !!!!
and it' off
Vintage Air lines secured and it looks so much better.
marty-mj
The Following 3 Users Say Thank You to syborg tt For This Useful Post:
camcojb (09-04-2023), Cramer4918 (09-04-2023), fleetus macmullitz (09-04-2023)
  #2246
Old 09-04-2023, 07:44 AM
thedugan's Avatar
thedugan thedugan is offline
What does the ceramic coating on the wheels do? Easier to clean brake dust?
Car is coming along great.
Doug L.
68 Camaro RS/SS Conv. LSA/T56
67 Camaro RS LS2/T56 "NutKse"
The Following User Says Thank You to thedugan For This Useful Post:
syborg tt (09-04-2023)
  #2247
Old 09-04-2023, 12:03 PM
syborg tt's Avatar
Exactly and once I start driving the car I will keep you posted on how well it does.
On a side not I am going to have him do the wheels on my Cayman and I am also going to change the pads from race to street pads.
marty-mj
Old 09-04-2023, 02:57 PM
I had Budnik do that to a set of their wheels on my GTO, made cleaning them like doing a chrome wheel. No more polishing, stayed much cleaner than a normal aluminum wheel.
The Following 2 Users Say Thank You to camcojb For This Useful Post:
syborg tt (09-05-2023), waynieZ (09-16-2023)
  #2249
Old 09-05-2023, 08:11 AM
syborg tt's Avatar
That is exactly what I am hoping for.
marty-mj
camcojb (09-05-2023)
  #2250
Old 09-21-2023, 09:45 AM
syborg tt's Avatar
Default Optima Battery Charge Cord (( 09-04-23 ))
Since the Optima needs constant charging with all of the on & off I have done with the ignition I decided to add the charge plug back on.
Tape is on & off again
Charge plug is back on.
Time to remove the blue tape from the Anvil Inner Fender
I had to remove the air filter so I could get the rest of the tape off.
I need to modify the little rubber things that go under the Anvil Radiator cover.
Ugh, the nutzert that I installed started spinning so I had to tighten it up again.
Anvil Radiator cover installed and I can't wait to see the Anvil Core Support cover installed.
I needed to clean out the threads on the factory blind nuts
marty-mj
camcojb (09-21-2023), fleetus macmullitz (09-21-2023)
